Post by gpw on Oct 30, 2012 18:30:56 GMT 1
Post by jonochap on Oct 31, 2012 0:29:00 GMT 1
So sorry, cannot see your image and the one I have dwnloaded is too big, will try again when I get some time tom : )
Post by jonochap on Oct 31, 2012 0:40:17 GMT 1
Ah, have managed to see the ones you have added....nope they are all mark 2 arms, the one I am replacing is a mk 1 single res...have taken a piccy and trying to sort out posting it never leave me alone with a pc!
Post by jonochap on Oct 31, 2012 7:15:06 GMT 1
It looks like this...
Post by gpw on Oct 31, 2012 9:12:54 GMT 1
. If you srill want help Jono , please will you tell me 1) the year of the vehicle and 2) if single or twin rear wheels, 3) disc or drum front brakes, 3) single or dual line system. If you are unsure aboutvany of this please email 1) a photo of the cylinder along with 2) the internal bore diameter.
Post by gpw on Oct 31, 2012 9:29:41 GMT 1
Sorry Jono, I didn't find your picture.
I need a picture of the cast iron bit.
Your pic shows the 1) white plastic reservoir 2) the black steel servo 3) a valve that limits the pressure at the rear brakes to stop them locking.
Working from you pictures, I now only need to know
1) the letters at the beginning of your VIN (on you log book) 2) if you have disc or drum brakes.
Post by jonochap on Nov 2, 2012 9:26:16 GMT 1
The brakes were rated so i think they are discs on the front and back, will post number and piccy of replacement unit this after when i have got it back from work...
Post by gpw on Nov 2, 2012 9:55:28 GMT 1
.Gulp, discs look shiny (unless you haven't used it for a long time). Drums look rusty, unless they are new. except, of course, if you've got a trailer tart. If you actually have got discs on the back , you will need non-standard master-cylinder, valve, etc..
Post by jonochap on Nov 2, 2012 15:51:10 GMT 1
Ok, thanks gpw, then you have my best guess at this...its a standard brakes and lining thing, which i think you are saying is drums then...not sure if the tart comment was meant for me or the trailer
Post by gpw on Nov 2, 2012 18:10:24 GMT 1
Trailer tarts are pampered motors that attend shows in a covered trailers Jono. Also called trailer princesses . Ok, drum brakes, what year is it please? It's best if you send me the letters of your VIN, that way I can find out the production year. Do you understand German?
Post by jonochap on Nov 2, 2012 18:55:38 GMT 1
Thanks gpw, when i open the doors and sort out the windscreen glass, will sort the vin, sorry, useless brick at languages, not bad with numbers
Post by gpw on Nov 2, 2012 18:59:57 GMT 1
Post by jonochap on Nov 2, 2012 18:59:58 GMT 1
This is where we started, part picked up. Doesnt look pretty but assured it will work when fitted...
Post by jonochap on Nov 2, 2012 19:01:42 GMT 1
Hour or so with a wire brush attachment to a drill and then slobbered with anti rust stuff has turned it into a smurf
Post by gpw on Nov 2, 2012 19:52:46 GMT 1
I suggest you 1) lightly hone the walls of the cylinder, 2) flush it out well, 3) rebuild it with new seals lubricated with rubber grease 4) refill with DOT3 brake juice, (the additives in DOT3 last longer).
before you fit it Jono.
Whilst you are at it, new brake hoses would be money well spent, unless yours have been replaced recently.
Incidentally, Lidl have a hydraulic trolley jack on sale this week at what looks a very good price.
