Post by irishtransit on Apr 11, 2013 17:22:45 GMT 1
has anyone got a pic of the difference between phase 1 and phase 2 please.no one know the answer to me other question?
Post by yorktransitman on Apr 11, 2013 19:35:20 GMT 1
have a look either on Google images or even Flickr, sorry i do not know your name other than your registered name 'irishtransit'
Post by irishtransit on Apr 11, 2013 20:05:26 GMT 1
the names john.
Post by yorktransitman on Apr 11, 2013 20:44:07 GMT 1
John, wasn't the actual headlamp the same & it was just the grille/indicators that were different?, i've just looked to see if i had an old Lucas parts book to see if i could confirm it but they only list car applications, i know the Escort MK2 GL/Ghia had a similar looking headlamp the glass i think was the same but the brackets were different so they will not fit
Post by irishtransit on Apr 11, 2013 23:16:39 GMT 1
found a bit somewhere that says the phase 1 has 3 tabs and the phase 2 has 1 but i'd like to see a pic of both as there is a couple on ebay but i don't know the difference.
Post by paulmonlwbv6 on Apr 12, 2013 1:53:10 GMT 1
hi,phase 2 has three tabs.used a h/light from a mk2 escort on mine.2 at bottom 1 at top
Post by irishtransit on Apr 12, 2013 9:46:59 GMT 1
cheers
Post by FredTransit on Apr 13, 2013 12:08:25 GMT 1
the phase1 and 2 has different fittings and adjusters. The phse2 has adjusters that slide into the tabs on the headlight. We only have one genuine phase1 and I have only had the headlamps off once but I seem to to remember they were more like the Mk1. She is a pop though with round headlights.
Post by irishtransit on Apr 13, 2013 14:19:11 GMT 1
all my vans have square headlights would they still be phase 1 lights then or could they all have been changed?if they are ph1 can ph2 lights be used with modification?
Post by FredTransit on Apr 13, 2013 18:23:04 GMT 1
The phase1 customs have square halogen headlights. The populars have round ones. All phase2s have square headlights. The phase1 custom is why we get away with 'backdating' phase2s for the camera
Post by irishtransit on Apr 13, 2013 20:37:18 GMT 1
i'm getting even more confused now.my amby is in members vans and it has square headlights but i doubt it is custom so are they phase 2 then?
Post by yorktransitman on Apr 13, 2013 22:05:05 GMT 1
i've just looked at your photos, you have certainly got your work cut out there John, yes the headlamp saga seems to have bought up many suggestions, maybe photograph yours may help?
Post by yorktransitman on Apr 13, 2013 22:17:10 GMT 1
Post by yorktransitman on Apr 13, 2013 22:31:36 GMT 1
i'm the bee's knees, i've only found photographs of both types in an old parts book the 78-83 is a halogen with 3 point mounting (two at bottom & one in the middle at the top) also fits Escort MK2 75-80. the 84-85/6 type, there are no mounting points looking directly at it in the photo which may be the one i have linked off ebay which my catalogue may not show the bracket it for some reason?, wasn't it mounted in a outer retaining frame like the round sealed beam idea?
Post by irishtransit on Apr 14, 2013 1:40:02 GMT 1
cheers for that lot at least i know what fixings to look for.
