Trevor
Sept 2, 2013 20:56:48 GMT 1
Post by semihemi on Sept 2, 2013 20:56:48 GMT 1
How did the France trip go?im off next week in mine...
Post by bobdragon12 on Sept 3, 2013 8:02:44 GMT 1
French trip went well , slight rear axle leak but nothing serious as had tools to fix . The only thing I would like to point out is if you have breakdown assistants it does not work on French motorways and its all a bit complicated so if you have problems try to not do it on a motorway or try an get off ;-)
Trevor
Sept 3, 2013 9:30:03 GMT 1
Post by FredTransit on Sept 3, 2013 9:30:03 GMT 1
been there done that. Theres some dodgy French law that only allows 'approved' contracters to recover off motorways. Once had a Saviem attend me with a broken spec. That went away to be replaced by a Cargo 0813 with no brakes. So the law does work keeping the cowboys out. NOT.
Trevor
Sept 3, 2013 15:17:09 GMT 1
Post by semihemi on Sept 3, 2013 15:17:09 GMT 1
Broke down last year on the south coast,starter motor,cost me a fortune to get a new one..
Post by bobdragon12 on Feb 7, 2014 18:15:14 GMT 1
Trevor
Feb 7, 2014 18:53:24 GMT 1
via mobile
Post by FredTransit on Feb 7, 2014 18:53:24 GMT 1
tidy work there. Have you road tested yet?
Post by bobdragon12 on Feb 7, 2014 19:04:16 GMT 1
Post by bobdragon12 on Feb 7, 2014 19:06:31 GMT 1
No road test yet still need to wire a couple of bits up and sort the cooling system as I seem to have an air lock , either that or the stats stuck
Post by bobdragon12 on Feb 7, 2014 19:08:10 GMT 1
Also had to cut down the centre box to get it to fit , the whole system came from a mk4/5 jumbo and I assume the rear axle is further back ?
Post by bobdragon12 on Feb 7, 2014 19:10:50 GMT 1
Also learn today that although my van has a fuel return it helps if it is actually connected to the tank, large puddle of Derv before I noticed.
Trevor
Feb 7, 2014 19:56:48 GMT 1
Post by dodgerover on Feb 7, 2014 19:56:48 GMT 1
That fan sensor adaptor looks nice, did you turn it up yourself?
Post by bobdragon12 on Feb 7, 2014 19:58:10 GMT 1
That fan sensor adaptor looks nice, did you turn it up yourself? No mate it was eBay
Trevor
Feb 7, 2014 23:49:50 GMT 1
Post by muttleymk2 on Feb 7, 2014 23:49:50 GMT 1
Coming on nicely, it will be interesting to see how well it goes
Post by bobdragon12 on Mar 27, 2014 12:18:03 GMT 1
Well got some larger injectors in , and turned the pump up . Pulls like a train . I have still to turn the turbo boost up until I get a working gauge . Popped into the scrappy on the test run and finally got Trevor weighed . 2.8tone with me in so about 2.68tones . Now I know why the Pinto was so bad
Post by bobdragon12 on Apr 22, 2014 18:33:25 GMT 1
Really need to change the diff , runs really well but can't go faster than 50 without going deaf
