Post by corktina on Jul 4, 2013 16:52:56 GMT 1
Passed it's test today, getting taxed tomorrow. Has new double passenger seat also now...amazing what a good scrub and a power-wash can do...
Post by RDTranny on Jul 4, 2013 19:55:35 GMT 1
Yeah! Happy holidays! :-)
Post by corktina on Jul 4, 2013 20:11:41 GMT 1
indeed! Palnning to visit the preserved Railway at Downpatrik and the Museum at Cultra, both in Northern Ireland as my first long trip.
Daughter,bf and baby intending to hi-jack Duck shortly too (hence the double seat
Post by muttleymk2 on Jul 4, 2013 23:26:25 GMT 1
Mucho congrats matey, she is looking fine inside now
Post by corktina on Jul 5, 2013 6:57:55 GMT 1
she is driving nicely....will do 60 comfortably on a good road, and on a bad one \i just let her take her time and use the 3rd overdrive a lot...quite relaxing. Steering a bit vague though
Post by RDTranny on Jul 5, 2013 13:59:59 GMT 1
Steering a bit vague though You can tighten the steering by setting the steering wheel in the straight ahead position then loosen the nut on the spindle of the steering box. Then using a screwdriver gently tighten the spindle not to tight or the steering gets too heavy. Retighten the nut and you should be good.
Post by corktina on Jul 5, 2013 14:26:40 GMT 1
not sure about that. If it's the same set up as on a Cortina mk1/2 , all you are doing is taking out the slack in the bearing and potentially increasing wear....on a Cortina it just makes the steering a little heavier but all the play is still there
Post by RDTranny on Jul 5, 2013 19:34:23 GMT 1
I don't know anything about the cortina boxes but I have adjusted the one on my van as it was very slack. It worked a treat. I'm open to correction but I think the idea is that the adjustment just takes up the slack in the worn gears so shouldn't affect the bearings.
Post by corktina on Jul 5, 2013 22:01:27 GMT 1
hmm, I might try it then..
got the fridge working on battery...not sure if I can get it to work on gas....working on it. Electrolux RM122F if anyone has a working one for sale
Post by bambimk1 on Jul 5, 2013 23:30:58 GMT 1
Be careful adjusting the steering box.Jack the van up after adjusting it and make sure it locks side to side without sticking.I can have a peek at it foc when you pass by on your way to Cultra .I am near Dublin.
Post by corktina on Jul 6, 2013 9:09:51 GMT 1
that sounds good! From memory of driving them back in the day, they were always a little vague anyway...I'll call in anyway, will contact you nearer the day
Post by munsterboy on Aug 4, 2013 10:30:30 GMT 1
Halo Corktina, has Duck found a new home yet?
Post by corktina on Aug 4, 2013 13:29:20 GMT 1
not yet, had three enquiries which didn't lead anywhere (wanted swaps) Not really in a rush, just testing the market really as it probably won't sell before the spring and I intend getting a bit more use out of it forst....
Post by FredTransit on Aug 5, 2013 9:36:47 GMT 1
you're selling??
Post by corktina on Aug 5, 2013 17:43:38 GMT 1
change of plans...one of the reasons for getting it has fallen by the wayside (Daughters fiancé can't get insured on it) so probably will go if a buyer should come forward.
