Post by irishtransit on Nov 10, 2012 23:14:20 GMT 1
would anyone know if the a pillar on a mk1 is the same as the mk2?say yes please.
Post by gpw on Nov 10, 2012 23:32:27 GMT 1
I've seen Mk2 doors on Mk1s, so I'd guess it's within spitting distance the same Irish. ;D
Post by irishtransit on Nov 10, 2012 23:34:36 GMT 1
that's good just gotta track one done.i've pm'd debstar so fingers crossed.
Post by gpw on Nov 10, 2012 23:47:50 GMT 1
Whoa there Irish, I'm guessing based on someone fitting Mk2 doors.
Suggest you PM Muttley before you lay out euros, he will know one way or the other.
Post by irishtransit on Nov 11, 2012 0:13:44 GMT 1
ookaaaayy!
Post by FredTransit on Nov 11, 2012 15:12:30 GMT 1
yes the pillar is the same. No the dash isn't so it would be difficult to match the two. HOWEVER. I need a good Mk1 scuttle/dash/pass A pillar and have the part on a MK2. If you find one wanna swap? Also debsters is a parcel van based on a chassis cowl with a plasic dash {or st least my Mk2s are} so wont help you on 2 counts
Post by irishtransit on Nov 11, 2012 18:23:11 GMT 1
yes the pillar is the same. No the dash isn't so it would be difficult to match the two. HOWEVER. I need a good Mk1 scuttle/dash/pass A pillar and have the part on a MK2. If you find one wanna swap? Also debsters is a parcel van based on a chassis cowl with a plasic dash {or st least my Mk2s are} so wont help you on 2 counts so if i got the one from debster could i use say the lower half where the hinges etc are and then sort out the top part later?i must admit she does look a task as the roof part above the windscreen is quite rotten aswell.i'll try and get pics tomorrow as i'd like to get her sorted but i need expert advice.
Post by FredTransit on Nov 11, 2012 23:37:29 GMT 1
no mate the dormobile is totally different!! It is a chassis cowl so theres no A post or not one like the van or cassis cab. Dont make me take pictures.......
Post by FredTransit on Nov 11, 2012 23:39:27 GMT 1
also the dormobile has sliding doors.....
Post by irishtransit on Nov 12, 2012 0:01:23 GMT 1
go on go on go on ya know you like pictures. so really i need one from a standard tranny.
Post by FredTransit on Nov 12, 2012 0:03:42 GMT 1
I shall taunt you with images of my lovely Mk2 scrapper tomorrow.
Post by irishtransit on Nov 12, 2012 13:59:14 GMT 1
thank you.i'll make sure i have some tissues handy!!!
Post by muttleymk2 on Nov 12, 2012 18:25:43 GMT 1
Screen and dash from scrapper have home to go to already Does your amby have standard pillars?
Post by FredTransit on Nov 12, 2012 19:21:53 GMT 1
damn I forgot. I think the amby in question is a Hanlon like Bell so yes normal pillars.
