Post by inchil2000 on Nov 10, 2013 17:57:05 GMT 1
need some help ive been offered a 1979 mk 2 ford transit camper the one with the bed over the cab its a 6 birth in great condition 2 litre pinto engine 84000 on the clock 10 months mot with no advisories on last mot only problem is its all bright yellow which i can have sprayed he wants 2000 for it . is this a good price any advice please
Post by irishtransit on Nov 10, 2013 18:49:23 GMT 1
I think on ebay decent one's are going around the £1200 mark.is it in exceptional condition?
Post by inchil2000 on Nov 10, 2013 18:53:55 GMT 1
its of a friend we have had a look at it it does look in good condition but never had one before so not 100 percent sure . it will need a respray as its all bright yellow with a black stripe down the center
Post by dodgerover on Nov 10, 2013 19:29:38 GMT 1
A respray isn't going to be cheap unless its just a quick blow over of the cab? If its dry (check with a damp meter in the corners) and the interior is tidy enough then I don't think it's particularly dear - its not outstandingly cheap either mind you.
Post by FredTransit on Nov 10, 2013 19:33:39 GMT 1
its a little bit high. If its in very good condition maybe £1500 might be nearer. You dont metion tax, if there is none remember you have another £230 on top of that. Insurance would be reasonable too. If you really hate the colour hand painting the body is easy cheap and not as horrendous as it sounds. A pro paint job would be 1000s mind.
Post by phorbiuz on Nov 10, 2013 20:47:08 GMT 1
Pictures would help.
Stucture is more important than your colour issue - rust, damp etc all cost money to fix. If you're definitely against the colour it will cost you a good chunk to sort unless you do a DIY job.
Post by buxvan on Nov 22, 2013 23:02:26 GMT 1
Bright yellow is a brilliant colour. Don't respray it. Like the other posts, look forr rust or damp. Good luck.
