Post by phorbiuz on Mar 7, 2014 21:36:48 GMT 1
Pictures to follow to clarify when I'm back home, but I'm after the following please:
Front door lock surround. Small black plastic between the push down / pull up lock button and the door metal.
Brake reservoir cap. Two caps on mine. Need the rear one with the electrical connectors.
Sidelight bulb housing. Rubber housing that holds the sidelight in the light itself.
Thanks.
Post by muttleymk2 on Mar 7, 2014 23:04:53 GMT 1
Can do your little lock pin surrounds, sidelight holder is absolutely the rarest of rare things, will look for master cyl cap
Post by phorbiuz on Mar 9, 2014 20:52:20 GMT 1
Cheers Muttley. I'm back home tomorrow so I can put a couple of pics up just to be sure. Getting the lock surround and a working brake cap would be great.
Post by phorbiuz on Mar 11, 2014 20:35:45 GMT 1
Any joy Muttley? Pics just to clarify. The brake reservoir has 2 caps and I'm after the one that plugs in.
Post by muttleymk2 on Mar 11, 2014 23:23:45 GMT 1
Will look Thursday
Post by FredTransit on Mar 12, 2014 10:36:48 GMT 1
have you no sidelight bulb holder at all? If it's just hardened and won't stay in, gaffer tape is your friend
Post by phorbiuz on Mar 13, 2014 16:42:39 GMT 1
The holder is there, just that on the other side it has a 'ridge' which pops into the headlight to keep it in place. The one I want to replace doesn't so just falls out. As it's a rare part gaffer tape it is!
Post by muttleymk2 on Mar 14, 2014 22:41:46 GMT 1
Got 2 lock surrounds but no luck with cap yet, I do have one, somewhere
Post by phorbiuz on Mar 20, 2014 20:54:59 GMT 1
Any progress? My resto is on its final stages now except where some paint needs redoing. Roll on the warm weather and classic shows.
Post by muttleymk2 on Mar 20, 2014 21:17:39 GMT 1
Can send you the surrounds but no joy with cap
Post by phorbiuz on Mar 23, 2014 16:48:23 GMT 1
Thanks Muttley. Just need one surround for the drivers door. I'll pm you.
If anyone else can suggest a source for a brake cap I'd appreciate it.
Post by irishtransit on Mar 23, 2014 23:25:14 GMT 1
no expert but wouldn't a Cortina cap fit?
Post by phorbiuz on Mar 24, 2014 11:26:06 GMT 1
Funny you should mention that... Just brought a mk4 home at the weekend so will be checking later in the week.
