Post by janine67 on Mar 20, 2014 18:46:30 GMT 1
Hi all this is my first post and I'm hoping someone can help. My family have recently become the proud owners of Daisy, a 1985 motorhome. Our mechanic has advised us we need a front wheel hub. Does anyone know where I could buy such a thing? So it's a wheel hub for a b reg ford motorhome. Thanks in advance.
Wheel hub
Mar 20, 2014 19:39:55 GMT 1
via mobile
Post by FredTransit on Mar 20, 2014 19:39:55 GMT 1
Welcome! You need to tell us if its a five or six stud wheels you have fitted.
Post by janine67 on Mar 20, 2014 21:21:12 GMT 1
Sorry about that. The hub is a 5 stud. Hopefully I'll be lucky as hoping to go to euro Disney in the summer in it. Thanks.
Post by davev6newman on Mar 23, 2014 20:30:37 GMT 1
What did he say was wrong with hub? as i cant see what goes wrong apart from the bearings, or did he mean the disc is shot?
Post by janine67 on Mar 24, 2014 16:49:27 GMT 1
Hi the mechanic said the bearing has been over tightened, the result is the outer ring of the bearing, instead of not moving, spins on the hub. This is makes it noisy and will cause it to heat up on long journeys.
Post by muttleymk2 on Mar 24, 2014 21:15:40 GMT 1
If the bearing race is spinning then you need a hub and a stub axle, not an easy thing to find. I will have a check of my stock and see if I have one.
Post by janine67 on Mar 25, 2014 17:11:56 GMT 1
The bearing is spinning. I'd be very grateful if you could check. As I mentioned we just got the van and are really looking forward to using it.
Post by peterg on Mar 26, 2014 21:53:53 GMT 1
