Post by phorbiuz on Aug 30, 2014 20:35:57 GMT 1
I'm in the middle of changing my standard 4 speed box for a 4 speed plus overdrive and I've hit a minor issue. Hoping someone on here more in the know can help.... The speedo cable gear is different. The 1st picture below shows the original 4 sp which has a square connection that screws in place. The 2nd pic is from the O/D box which has a more rounded connection that seems to push on and be held in by a clip and nut. Unfortunately the 2 gears aren't interchangeable as they're different gear sizes inside. So does anyone know what cable I need to order here, just in case it's not as obvious a "speedo cable for a mk2 Transit with OD". I guess I don't actually know if this new box is from a mk2 or possibly a mk1 or 3.
Post by muttleymk2 on Aug 30, 2014 22:33:09 GMT 1
There are two types of cable fitted to Mk1 and 2's, I can look see if I have the one for your O/D box
Post by phorbiuz on Aug 31, 2014 7:26:00 GMT 1
Cheers bud. Let me know if you find anything, though I don't mind asking my local factors to see if they can source one - just needed to know I wouldn't look stupid ordering another wrong one.
Post by muttleymk2 on Aug 31, 2014 16:31:40 GMT 1
You would have to look at the cable they have to check the end.
Post by phorbiuz on Sept 1, 2014 20:00:57 GMT 1
Well my local factors can't help. To be fair to them they don't supply ANY speedo cables any more. Hopefully this won't be a problem part to find and I've messaged Dave (aka Bentley Boys) to see if he can help.
Post by peterg on Sept 1, 2014 22:14:49 GMT 1
