Post by dodgerover on Feb 15, 2015 16:49:37 GMT 1
The new one looks really familiar but I just can't place it. Maybe Mitsubushi or a modern 4x4?
Post by troppo on Feb 16, 2015 0:45:30 GMT 1
Thanks fred but i`ll tidy up the one i have, it has an intermitant vacuum problem but i`m guessing thats the check valve. I`ll replace that and see if it makes a difference. i wish there was a way i could modify the old master to fit the new booster as it seems bigger and is definately is in better condition
Post by dodgerover on Feb 16, 2015 14:10:54 GMT 1
knew I'de seen one somewhere Try looking for a Mitsubishui Sigma or Nissan Stanza in the wreckers Had a quick look on google images with the search term Sigma Brake Booster and got the following pic: no other info apart from the pic though
Post by travla on Oct 4, 2015 8:38:40 GMT 1
Just found your posts on the booster & master cylinder . Can't view the second photo but the first photo is the same as mine it's on a 77 twin slider Aussie camper . My booster is stuffed & they've quoted me big bucks to kit it & it's been done b4 can anyone tell me if a booster & master cylinder of something else can be made to fit without to much drama . Cheers .
Post by cadill69 on Oct 4, 2015 10:28:59 GMT 1
I took my off and had it rebuilt by Automotive Brake Reconditioning at 46 Adderley St Lidcombe NSW 2141, Australia Phone 02 9748 4944. They supply the brake companies. Cost me about $300 a couple of years ago. Easy to remove and I picked it up the next day. Can's see why they cant be rebuilt any number of times. Stick with original otherwise your thrust can be all over the shop. They can do your master cylinder too but you need to supply the kit (stainless steel sleeves).
Slider!! Lucky you. Only disadvantage is no side door. Welcome.
Post by retiredtruckie on Oct 4, 2015 10:47:41 GMT 1
I was quoted $380 at ABS Adelaide to have mine reco'd and welcome
Post by FredTransit on Oct 4, 2015 11:59:14 GMT 1
Just found your posts on the booster & master cylinder . Can't view the second photo but the first photo is the same as mine it's on a 77 twin slider Aussie camper . My booster is stuffed & they've quoted me big bucks to kit it & it's been done b4 can anyone tell me if a booster & master cylinder of something else can be made to fit without to much drama . Cheers . Welcome travla! If all else fails, you could try Ralph. I am sure he would post to you.
Post by travla on Oct 4, 2015 21:12:37 GMT 1
Thanks for the info & welcome guys , I'll have a bit of a think about it .
Post by martinp on Oct 9, 2015 23:42:52 GMT 1
Hmm that is the exact same as what is on my MK1 aussie beast. Not sure if it works yet as I'm yet to get the thing to start. Keep updating this post as to what it is off, I'm guessing a falcon cira 1975-77.
Post by cadill69 on Oct 10, 2015 0:26:54 GMT 1
Here is an Aussie MK1 6 cyl booster/master
Post by retiredtruckie on Oct 10, 2015 2:01:10 GMT 1
That looks like the one on my 4cyl cadi
Post by martinp on Oct 10, 2015 2:29:42 GMT 1
Not like my mk1 77 Aussie tranny, it may not be an original one though. Mine looks like the one in the first photo posted.
Post by cadill69 on Oct 10, 2015 3:33:11 GMT 1
Here is another one with a different method of clamping the two halves. Reconditioners shy away from these as they are hard to separate. Came from my '74. The one above was from a '77.
Post by troppo on Oct 10, 2015 7:26:08 GMT 1
So does any-one know about the proportioning valve? Do i need it hooked up or can i get away with out hooking it up?
Post by cadill69 on Oct 10, 2015 7:43:50 GMT 1
Wont the back brakes lock up prematurely if you don't?
