Post by bambimk1 on Mar 10, 2015 0:20:01 GMT 1
Lift off the dash panel with the ashtray and check you have power at the multiplug where it goes out through the bulkhead.
Post by FredTransit on Mar 10, 2015 9:32:19 GMT 1
The first junction in the loom is in the glove box, dunno if this helps!
Post by jokeronline on Mar 12, 2015 22:51:32 GMT 1
The junction by the glove box is not where the indicator wires go through. I have managed to sort the problem and got them working now. There was a broken wire in the wiring loom. had to strip it back to find it
Post by troppo on Mar 12, 2015 23:26:36 GMT 1
Good to hear you got it fixed
Deleted
Deleted Member
Post by Deleted on Mar 14, 2015 8:32:17 GMT 1
They really didn't think the front indicator through fully exposed to everything the wheel throws up at it. As Fred has mentioned most likely the wire is corroded in the buld terminal connection!
Post by fortyeight on Apr 12, 2015 9:46:54 GMT 1
the feed is picked up from the indicator switch ,so if you find the nearside live on the switch you could run a seperate new wire to the bulb holder ,if your struggling to trace the aridginal wire
