Post by broon4 on Apr 10, 2015 18:56:42 GMT 1
had a mishap today driving along when offside headlight glass fell off, and smashed.
can anyone tell me if they are handed ?? and are they supposed to be a sealed unit ?
cheers broon
Post by muttleymk2 on Apr 10, 2015 21:45:03 GMT 1
Mk1 or 2, mk1 can be sealed beam if it's early, all mk2 have bulbs if they are square, some have sealed beam if they are round. Easy to see if you have a bulb from the rear of the unit.
Post by FredTransit on Apr 10, 2015 22:00:50 GMT 1
Mk1 sealed beam. Mk2 phase1 round are (early 78-81) sealed beam, late bulbs, all square are Halogen, as are all phase2s. The headlights don't have separate glass. The sealed beams are handed. Square headlights not handed.
Post by broon4 on Apr 10, 2015 22:58:02 GMT 1
sorry mk2 square bobdragons old camper metal grill is that phase 1 ?
Post by FredTransit on Apr 11, 2015 11:00:00 GMT 1
Metal grille is a phase1, yes. All my spare headlights are phase2 and a different fitting.
Post by broon4 on Apr 14, 2015 7:05:26 GMT 1
ok thank you have ordered one off ebay just hope it fits, local motor factors can't get one
Post by broon4 on Apr 14, 2015 20:00:17 GMT 1
ok so new headlight arrived today, but fixing points different. looks like phase 2
my light has two hooks for adjusters and one fixing point at bottom right corner
new light adjusters are sockets on back with a fixing point in the middle at bottom...
can you get new bowls for phase 2 light ? that seems easiest way to solve problem
cheers broon
Post by muttleymk2 on Apr 14, 2015 21:27:30 GMT 1
Phase 2 has a different method of fixing, you would need to convert to phase2 front panel, a lot of work!
Post by broon4 on Apr 15, 2015 17:03:30 GMT 1
could i not use a phase 2 headlight bowl ??
Post by FredTransit on Apr 15, 2015 19:13:26 GMT 1
When you say bowl, do you mean the bit that the bulb goes through? The phase2 light doesn't have a separate bowl.
Post by broon4 on Apr 15, 2015 20:59:02 GMT 1
ah rite i just assumed they had a bowl like a mk2 escort, but its fine have tracked down a phase 1 light. they are the same as a mk2 escort ghia
Post by FredTransit on Apr 15, 2015 21:25:46 GMT 1
I heard they were the same as the escort, but wasn't sure if the fixings were the same.
Post by muttleymk2 on Apr 15, 2015 21:37:20 GMT 1
Yeah, same as Escort, same as facelift D series too
