Post by FredTransit on Mar 4, 2016 12:25:56 GMT 1
At least the info is here for anybody else who needs it. Dan some LWB models have vented discs but not sure which SWB. Maybe the minibuses? I'll get Muttley to have a look for you.
Post by danclift on Mar 4, 2016 15:49:44 GMT 1
yea mine are like the ka brakes fade under heavy braking they work but could be better tho i bled all 4 corners when i replaced the rear cylinders so know thats all good
Post by dodgerover on Mar 4, 2016 16:40:59 GMT 1
Maybe some better pads on the front would help with fade? Mine don't fade with normal road use and I'm a lot heavier
Post by muttleymk2 on Mar 4, 2016 22:34:22 GMT 1
What the hell are you doing to get brake fade? I have driven SWB vans with solid discs towing up to capacity up hill and down dale, never had brake fade. It's an old van you are driving, not a rally car
Post by bambimk1 on Mar 4, 2016 22:52:08 GMT 1
190 had vented discs.Never seen single wheel ones with discs.
Post by danclift on Mar 6, 2016 21:05:15 GMT 1
Maybe some better pads on the front would help with fade? Mine don't fade with normal road use and I'm a lot heavier mine do and im only 10 stone.
Post by danclift on Mar 6, 2016 21:07:13 GMT 1
What the hell are you doing to get brake fade? I have driven SWB vans with solid discs towing up to capacity up hill and down dale, never had brake fade. It's an old van you are driving, not a rally car although i have seen the mk1 mk2 being used for rally driving tho
Post by dodgerover on Mar 6, 2016 22:13:36 GMT 1
Maybe some better pads on the front would help with fade? Mine don't fade with normal road use and I'm a lot heavier mine do and im only 10 stone. If I get to the stage were my lard arse is making the brakes fade on a 3.5t van then I'll have more to worry about than stopping..... I'm loaded up most of the time somewhere around 2.5 ton or more
Post by muttleymk2 on Mar 6, 2016 22:29:53 GMT 1
What the hell are you doing to get brake fade? I have driven SWB vans with solid discs towing up to capacity up hill and down dale, never had brake fade. It's an old van you are driving, not a rally car although i have seen the mk1 mk2 being used for rally driving tho Towing a trailer with a Rally car on it, not rallying
Post by danclift on Mar 6, 2016 23:57:45 GMT 1
although i have seen the mk1 mk2 being used for rally driving tho Towing a trailer with a Rally car on it, not rallying no i mean ive seen the van being used for rally
Post by muttleymk2 on Mar 7, 2016 14:06:03 GMT 1
You are missing the point, if you have brake fade occurring then you must have worn or faulty brakes as the standard SWB solid discs are more than up to the job.
zephyrman
Driving Mk1 Daily, keep it as van/removable camper!
Post by zephyrman on Jan 28, 2018 20:44:17 GMT 1
Hi, so if wanting to fit callipers and discs to the existing drums , is it a case of getting the brackets and discs and calllipers. Do those parts fit to existing stubs or do I need to change the whole stubs?
Thanks
Post by muttleymk2 on Jan 28, 2018 22:20:43 GMT 1
You will need disc stubs, its a lot easier to change the whole axle
