Post by dodgerover on Apr 15, 2016 20:52:50 GMT 1
Be quick if you need anything - Karl over on the other forum is breaking up his green mk2 crew cab, it was the really really rough one from memory
Post by danclift on Apr 17, 2016 22:57:40 GMT 1
need the bottom few inchs of passenger wing if can find out for me
Post by dodgerover on Apr 18, 2016 11:11:48 GMT 1
Don't think there was much thin panel work left in front of the bulkhead
Post by skyrise on Apr 27, 2016 14:04:40 GMT 1
Hi ya..
I don't suppose there is the long bar behind the cross member.. I towed mine and managed to bend it nicely.. Track rod bar?
with the ends would be nice..
thanks
Post by sleepy on Apr 27, 2016 14:48:40 GMT 1
Hi ya.. I don't suppose there is the long bar behind the cross member.. I towed mine and managed to bend it nicely.. Track rod bar? with the ends would be nice.. thanks try Ralph... look in parts for sale section for his number he's breaking a mk2
Post by FredTransit on Apr 27, 2016 16:26:59 GMT 1
Hi ya.. I don't suppose there is the long bar behind the cross member.. I towed mine and managed to bend it nicely.. Track rod bar? with the ends would be nice.. thanks I am pretty sure you can bend it back mate. The RAC once did that to one of ours once. They did far worse but it's another longer story. Don't ever use the RAC.
Post by Ralph on Apr 27, 2016 17:04:22 GMT 1
I have a couple of good track rods, £30 each.
Post by cadill69 on Apr 27, 2016 22:59:08 GMT 1
With left and right threads at either end it will easily screw out. Will need a wheel alignment particularly if straightened.
zephyrman
Driving Mk1 Daily, keep it as van/removable camper!
Post by zephyrman on Apr 30, 2016 16:52:10 GMT 1
Any double or Bench seats?
zephyrman
Post by zephyrman on Apr 30, 2016 16:54:51 GMT 1
Post by harry2012 on Apr 30, 2016 22:53:26 GMT 1
Hi ya.. I don't suppose there is the long bar behind the cross member.. I towed mine and managed to bend it nicely.. Track rod bar? with the ends would be nice.. thanks I am pretty sure you can bend it back mate. The RAC once did that to one of ours once. They did far worse but it's another longer story. Don't ever use the RAC. You can. A Landrover Defender uses the same type of setup, I regularly bent mine off roading, just bash it straight and carry on, just remember it's fatigued so might bend easier next time.
Post by paulstransitmk1 on May 13, 2016 9:17:01 GMT 1
Is the rubber floor mat available and in good condition. Would also need the floor straps for securing down if available. Also the LH & RH footwell rubber mats and associated retainer brackets/straps
