Post by charlesk on Feb 19, 2018 0:52:04 GMT 1
Hello,
Got my van running again after a couple of weeks and there seems to be a rattle that appears under acceleration between certain rpm and then disappears again. When the the clutch is pressed while rattling, the rattle disappears, when clutch is released it returns. Van runs fine, not sure if this is a common/harmless sound or if something needs to be changed soon. What could be the cause of this sound?
2L 1982 petrol transit.
Regards,
Post by FredTransit on Feb 19, 2018 11:01:31 GMT 1
It could be the clutch release bearing. Is it the 4 speed or OD?
Post by bullsintransit on Feb 19, 2018 13:41:30 GMT 1
Poss.loose/rattleling baffle in 1st exhaust box?(easy fix,hammer),or gearleaver itself,filled gaiter where it goes into box with grease on mine,stopped rattle.
Post by FredTransit on Feb 19, 2018 18:45:14 GMT 1
Have you still got the heat shield on the exhaust manifold? They often rattle.
Post by charlesk on Feb 19, 2018 20:52:43 GMT 1
It could be the clutch release bearing. Is it the 4 speed or OD? Yes I believe it's only 4th speed. Is it likely to be the clutch release bearing and does it need replacing ASAP? Thanks.
Post by muttleymk2 on Feb 19, 2018 22:18:47 GMT 1
Try adjusting the clutch cable, it could be the release fork rattling.
