Post by irishtransit on May 6, 2018 23:40:37 GMT 1
this is all hypothetical at the moment until we know what is happening with the house but i was wondering how much can the chassis be repaired until it becomes dangerous? as some may recall the chassis on the minibus is quite rusty but fairly solid and in an ideal world the whole chassis would be replaced but that can't be done.i was wondering could it be replaced in say 3 foot long sections but not is normal sections?i'll try and explain the best i can.say for instance i cut the top half off where the floor is attached to about half way down on the outside edge.then done the same on the inside section but staggered along about a foot further than the front bit.then replace the whole bottom section again staggering it from the top sections something like brick laying.would it be safe enough if it was seam welded.
Post by corktina on May 7, 2018 8:25:04 GMT 1
i'd say getting it through the test will be a nightmare. They'll want an Engineers report for sure on the welding and I dread to think what he'd say
Post by irishtransit on May 7, 2018 15:21:05 GMT 1
true as they can be right donkey's over here but then again if i made such a good job on it and painted and seales it they might not notice lol
Post by muttleymk2 on May 7, 2018 21:24:14 GMT 1
Its all down to the quality of the welding, I have replaced all of the front chassis on Freds blue LWB and most of the rear. Its probably stronger than Fords made it
Post by corktina on May 7, 2018 22:52:38 GMT 1
true as they can be right donkey's over here but then again if i made such a good job on it and painted and seales it they might not notice lol that's true, they only ask for a report if they fail it on rust , so you might well be OK
Post by irishtransit on May 8, 2018 1:13:58 GMT 1
if we stay i think i'll give it a go and if i balls it up i don't have a lot to lose
Post by muttleymk2 on May 8, 2018 21:33:35 GMT 1
Quit with the negative vibes Moriarity
Post by irishtransit on May 17, 2018 17:05:05 GMT 1
what's the best way of making a template for the chassis rail? i want,well need don't want,to replace a 5ft section from just past where the chassis curves in from the rear going forward but i just got some rough measurements thru the wheel arch and it would appear that it is different heights from 100mm to about 110mm.so it appears that around the suspension area it is not as high would it make that much difference if i made it all one size or would it interfere with the suspension movement etc?
Post by muttleymk2 on May 17, 2018 21:39:50 GMT 1
Make up a cardboard temlpate of the panel you need then cut it out in steel.
Post by irishtransit on May 17, 2018 22:06:12 GMT 1
was thinking that.how hard is it to remove the spring as was thinking if i cut the chassis rai lout then the outriggers that hold it in place would move up and maybe hard to get back in place.of course all this depends if we stay here
