Post by semihemi on Jan 6, 2013 13:50:59 GMT 1
Probably one for Muttley but i had a problem with leaking from my lucas pump it was bad enough combined with the smoke from the engine for me to consider an engine swap..i have been out to it today and fired it up and found its leaking from the side of the pump,from what looks like a plunger held in with a circlip,i have turned this back and forth a few times and the leak has stopped!! any ideas what this plunger thing is for??its next to a plastic cap thing.also it seems to have stopped smoking..cant be anything to do with that can it??
Post by semihemi on Jan 6, 2013 16:32:37 GMT 1
Pump Details Type 1008 Ser 17998MKG Hope this helps
Post by muttleymk2 on Jan 6, 2013 18:00:00 GMT 1
I think you will find thats the max fuel stop adjustment
Post by semihemi on Jan 6, 2013 19:08:28 GMT 1
So have i done anything by turning it back and forth other than stopping it leaking?? Thanks Muttley
Post by muttleymk2 on Jan 6, 2013 19:24:24 GMT 1
What colour was the smoke? You have probably backed off the stop and its now not ovefueling.
Post by semihemi on Jan 6, 2013 20:27:45 GMT 1
it was both white and black depending on where you were with the pedal,white on the overrun. thing is it didn't feel like i was adjusting anything,whats under that plastic cap next to it Muttley?
Post by muttleymk2 on Jan 7, 2013 20:24:20 GMT 1
I think thats the hole to put the peg that locks the pump at TDC.
Post by semihemi on Jan 7, 2013 22:56:37 GMT 1
Thanks Muttley thats great
