Post by cadill69 on Mar 26, 2021 23:14:21 GMT 1
Haven't been on here for ages. How are you guys doing? Major rust work completed. Lpg donut tank now under where spare wheel was and spare wheel on bracket mounted behind left back door. Opening quarter vent windows and swivelling front seats. Next job is to replace pin on top hinge on left back door. Too much slop causing difficulty in closing. From my parts book it looks like a pin drops in from the top but on visual inspection and a quick grind l can't see anything. I haven't tried knocking it out from the bottom yet. I thought I'll check in with you guys. It is a 1974 mk 1 with phillip head screws holding hinges on. I thought l might drill a bigger hole and drop a hardened steel bolt in or can l get a NOS hinge? i.postimg.cc/Z5hDc1WK/20210326-133753.jpgi.postimg.cc/rz20WyZT/Tinkydoorpin.jpg
Post by cadill69 on Mar 26, 2021 23:49:53 GMT 1
Post by Ralph on Mar 27, 2021 7:48:09 GMT 1
In think I have new pin kits, I will have a look. I have new hinges as well £40 each?
Post by cadill69 on Mar 27, 2021 21:55:19 GMT 1
New hinge might be the way to go as l think the hinge itself might be worn. Be interested to see what the pin kits includes. Do the new hinges come with hardware? Also my plastic handle on the bonnet release just broke. Are these available? Thanks Ralph, I've bought from you before. Hugo, Sydney Oz. postimg.cc/z3whKdyB
Post by Ralph on Mar 29, 2021 6:53:09 GMT 1
Here's the new hinge & a used bonnet pull. Postage is £23.
Post by cadill69 on Mar 29, 2021 18:20:31 GMT 1
Excellent, thanks Ralph. I'll buy those. I'm just thinking are there two panels that fit on the inside of the rear quarters to cover the back of the lights? I have the two upper ones but the bottom ones have always been open.
Post by cadill69 on Mar 29, 2021 18:44:00 GMT 1
Also do you have the 4 plastic thingos that the bars lock into top and bottom when the handles are turned (back doors)?
Post by Ralph on Mar 30, 2021 6:52:10 GMT 1
Can you get a picture of the inner light cover? Yes I have the plastic lock rod bits, I will get a picture today to confirm we are talking about the same thing.
Post by Ralph on Mar 30, 2021 10:45:58 GMT 1
Is this what you mean?
Post by cadill69 on Mar 31, 2021 6:41:01 GMT 1
Yes. Brilliant. I'm thinking of replacing the barn door rubbers. Not the windows but the ones that go around the full rear door x 2. Are they available? Here is picture of the missing lower inside quarter panel. Thanks.
Post by Ralph on Mar 31, 2021 6:50:13 GMT 1
I am waiting for more door seals to come in, that is the only rear corner cover.
Post by cadill69 on Mar 31, 2021 6:59:38 GMT 1
Ok. Good to know. I'll make something up.
