ammeter
Feb 20, 2013 21:53:58 GMT 1
Post by fortyeight on Feb 20, 2013 21:53:58 GMT 1
hi anybody know how to wire up a ammeter on a mk2 cheers
ammeter
Feb 23, 2013 21:15:23 GMT 1
Post by muttleymk2 on Feb 23, 2013 21:15:23 GMT 1
Goes in the big cable coming from the back of the alternator. Cut the cable and extend the ends up to the ammeter.
Post by fortyeight on Feb 24, 2013 9:55:13 GMT 1
cheers for the reply
ammeter
Feb 26, 2013 15:37:06 GMT 1
Post by fortyeight on Feb 26, 2013 15:37:06 GMT 1
hi on the instuctions that came with it ,its going on about connecting to the solanoid which reads a bit complicated so does connecting it up to the big wire from the alternator do the same job,will i need thick wire like from the alternator
ammeter
Feb 26, 2013 20:13:56 GMT 1
Post by muttleymk2 on Feb 26, 2013 20:13:56 GMT 1
It depends on the meter, if it has large connectors then it goes in the big wire.
ammeter
Apr 10, 2013 21:15:30 GMT 1
Post by fortyeight on Apr 10, 2013 21:15:30 GMT 1
i think that way from the altinator is to connect a volt meter up i connected it to the solonoid where the batt cable goes,disconnect the batt cable at the solonoid,leaving the other wire on the soloniod, ,connect a leed from the ammetor to the soloniod where the batt cable as been moved together with the other wire that is on that connection, then connect the other leed from the ammeter to the batt leed ,if the ammeter reads the wrong way round ,then change the ammeter wires over, 60 amp cable must be used or it will burn out
