Post by twisty12 on Mar 14, 2013 15:18:32 GMT 1
Hi I need a bit of help with the wiring on a mk2 transit it's got a 2.0 pinto fitted, but someone has pulled the wiring off the starter motor and coil and I'm not 100% sure where they go can some one give me a simple break down of where to put them. So I can see if it runs before I spend any more money on it Many thanks Andy
Post by FredTransit on Mar 14, 2013 17:39:16 GMT 1
mk1mk2transit.freeforums.net/index.cgi?board=talk8&action=display&thread=3
would this help?
Post by fortyeight on Mar 14, 2013 18:39:33 GMT 1
hi just had a look at mine-coil wires ,red black wire to possative +terminal /green wire to negative - terminal starter with prengaged soliniod looking down at it,top right thick red possative+from battery and 2 red thickish wires fastend together,thin black yellow top left,thickish black yellow bottom right, thick black bottom left to starter,hope this helps
Post by twisty12 on Mar 14, 2013 19:55:24 GMT 1
Could you possibly post a pic of the starter with the wires in place
Post by fortyeight on Mar 15, 2013 11:31:26 GMT 1
sos dont know how to do it,lift the bonnet and look down at it,solaniod on top of the starter all the terminals are on the solanoid
Post by fortyeight on Mar 15, 2013 16:19:05 GMT 1
sos soloniod on right hand side of starter not on top
