spark
May 26, 2013 10:26:46 GMT 1
Post by comet on May 26, 2013 10:26:46 GMT 1
HELP,no spark at plugs, 2000cc pinto in mk1, electronic ignition,when i hold ht lead from coil to engine good spark.
spark
May 26, 2013 10:40:30 GMT 1
Post by jonochap on May 26, 2013 10:40:30 GMT 1
8-( has the dizzy been moved?
spark
May 26, 2013 10:49:15 GMT 1
Post by comet on May 26, 2013 10:49:15 GMT 1
i was just driving along motoway,and it cut out
spark
May 26, 2013 11:48:55 GMT 1
Post by FredTransit on May 26, 2013 11:48:55 GMT 1
Has an earth dropped off? Bizzarre burt actually happeened to me once. Could the king lead be breaking up?
spark
May 26, 2013 19:33:21 GMT 1
Post by muttleymk2 on May 26, 2013 19:33:21 GMT 1
Defective rotor arm
spark
May 26, 2013 21:38:54 GMT 1
Post by dodgerover on May 26, 2013 21:38:54 GMT 1
Carbon brush in the top of dizzy cap broken up or dropped out?
spark
May 26, 2013 21:47:20 GMT 1
Post by comet on May 26, 2013 21:47:20 GMT 1
could it be faulty modual - black box?
spark
May 26, 2013 23:00:53 GMT 1
Post by muttleymk2 on May 26, 2013 23:00:53 GMT 1
Rotor arm, u said u have spark from coil lead, take the dizzy cap off and put the coil lead to the top of the rotor arm, if it sparks to the arm then it's fecked
spark
May 27, 2013 10:11:38 GMT 1
Post by comet on May 27, 2013 10:11:38 GMT 1
i will try that muttley - just tried that no spark - the 2 wires going to the dizzy,how do i check if power there ?
spark
May 27, 2013 20:45:06 GMT 1
Post by muttleymk2 on May 27, 2013 20:45:06 GMT 1
Do u have spark at all? If not then check live and earth at the module, if u have both then module is faulty. That said I have never seen a duff one in 27 years If u have no earth, put in a seperate new one, same for live (ignition controlled of course)
spark
May 27, 2013 21:29:47 GMT 1
Post by comet on May 27, 2013 21:29:47 GMT 1
fitted another dizzy with points,doing away with electronic ignition, does it need balast resister
spark
May 27, 2013 21:51:19 GMT 1
Post by muttleymk2 on May 27, 2013 21:51:19 GMT 1
Good idea, you will need a points type coil as well though, buy a 12v coil and u dont need ballast
spark
May 28, 2013 16:08:25 GMT 1
Post by comet on May 28, 2013 16:08:25 GMT 1
fitted an intermotor 12v coil, running fine,thanks for all help
spark
May 28, 2013 20:48:48 GMT 1
Post by muttleymk2 on May 28, 2013 20:48:48 GMT 1
Sweet, simples is best (Fred wont agree though )
