Post by bobdragon12 on Jul 3, 2013 14:35:04 GMT 1
Does anyone know the part number for the seals that go in the rear hub as I have noticed what looks and smells like trans oil on both back wheels . Van is LWB DWB 6 stud .
Cheers jon
Post by bobdragon12 on Jul 4, 2013 11:26:14 GMT 1
Would my axle be classed as a type 34 ?
Seals
Jul 4, 2013 23:32:44 GMT 1
Post by bambimk1 on Jul 4, 2013 23:32:44 GMT 1
I don't have the finis no but I think they are still available in the main dealer I got 2 not long ago.If you have no luck I will get the no for you just let me know here.
Seals
Jul 5, 2013 23:33:44 GMT 1
Post by mk1andy on Jul 5, 2013 23:33:44 GMT 1
If you've got oil on the wheels it's more likely to be the half shaft gaskets. They're no longer available but easily made if you buy a sheet of gasket paper and use the halfshaft as a pattern. If the oil seal goes it's more likely to contaminate inside the drum and shoes themselves but you're less likely to see this without taking the drums off. I bought new seals for mine last year, they're still available from Fords, finis code is 6048469. Not cheap though, about £33 each (retail) plus vat. Always worth asking and pushing for a trade price, I made friends with my main dealers and it's saved me a fortune over the years. The old part number that is stamped on the inside of the seal is 76VB 1176 AA. Hope this helps you.
Seals
Jul 6, 2013 10:16:09 GMT 1
Post by FredTransit on Jul 6, 2013 10:16:09 GMT 1
top info andy, good on yer!
Post by bobdragon12 on Jul 6, 2013 10:25:51 GMT 1
Fab info Andy , will have a look
