Post by corktina on Mar 16, 2014 10:47:50 GMT 1
My headlight/indicator/ rear light bezels and also grille are a naff grey plastic which is faded and scruffy. What can I do to re-vitalise these and also, I need a new drivers side indicator bezel...are these easy to get?
Post by FredTransit on Mar 16, 2014 12:16:56 GMT 1
there are no seperate bits on the lights mate. They are all one unit. Try cleaning the plastic then rubbing em with smooth peanut butter. If that doesnt work, try carefully masking the lenses and spraying them with grey bumper and trim paint. Holts do one.
Post by corktina on Mar 16, 2014 13:05:48 GMT 1
so what I need is a complete new indicator unit? Probably not a bad idea anyway as I see the lens is held on with woodscrews... I'm guessing they can't be got new form Ford
Post by corktina on Mar 16, 2014 13:06:30 GMT 1
PS if I paint them, I shall paint them white and add viper stripes as in the Transit Sport.... :-)
Post by muttleymk2 on Mar 16, 2014 21:42:42 GMT 1
PS if I paint them, I shall paint them white and add viper stripes as in the Transit Sport.... :-) U might get banned
Post by conrod on Mar 19, 2014 22:27:22 GMT 1
The bezels on my early Mk2 were grey and oxidised. I refurbed them by wet sanding with 400, then 800, then polishing with cutting compound (T-Cut to you poms) and they came up like new. Took an hour or two to do. Not sure if the later bezels are the same though?
Conrad
Post by corktina on Mar 20, 2014 4:37:01 GMT 1
they are plastic so oxidisation isn't a problem for once. :-)
Post by conrod on Mar 20, 2014 4:59:45 GMT 1
thats true!
Post by sidewaysjas on Mar 21, 2014 23:48:08 GMT 1
New old stock indicators seem to come up quite often on ebay. If you decide to paint them I'd use a plastic conditioner/primer to make sure the paint stays on a nice long time. Jas
Post by corktina on Mar 22, 2014 9:49:26 GMT 1
I'll keep looking then....only seems to be the lens I see.
