Post by FredTransit on May 6, 2014 14:37:39 GMT 1
Following Beryls recent paint, I decided to replace her indicaters. You guys out there with phase1 Mk2s have it easy. The phase2s are a nightmare! The wrap around design obscures the silly spire nut tab things, making it hit and miss when trying to screw the light unit into the wing. At least three times they pinged off the wing. What fool thought that was a good idea?
Post by sidewaysjas on May 6, 2014 21:58:51 GMT 1
Yes, what a complete and utter pig to do, mine currently are only held on by two screws a side as I just can't find the holes through the indicator. Perhaps when they were a new van Ford mechanics were sent on a course on how to refit them! Jas
Post by FredTransit on May 7, 2014 9:56:34 GMT 1
.......and then if the tabs on the wing rust away (likely) what do you do? At least one of ours has lumps of chemical metal with holes drilled in em! Works ok though and the wing is othewise sound. It actually works better cos you drill the holes with the light io place.
Post by corktina on May 7, 2014 20:26:30 GMT 1
the Mk2 Cortina are similar...those tags are often gone and chemical metal is common
Post by dodgerover on May 7, 2014 20:29:48 GMT 1
Tags have gone on the wing i'm replacing too..
Post by muttleymk2 on May 7, 2014 21:20:21 GMT 1
I made repair panels for Shorty's indicator holes
