Deleted
Deleted Member
Post by Deleted on May 22, 2014 21:30:52 GMT 1
Saw a lovley V6 conversion and it's made me want to consider it. I have a mk2 tipper which is converted to Di and 5 speed as my daily work truck. I love my Di but it's SO noisy in there! Anyone have any real world MPG useage figures. I'm just about to do a proper mpg test on the Di to see what I'm actually getting as this will be my main deciding factor as to considering a change. Also does anyone know if the Essex V6 bolts up to the MT75 gearbox? Other arguments for considering the change is reduced can noise, no LEZ issues (not that I actually need to yet) and of course the lovley V6 sound
Post by FredTransit on May 22, 2014 22:05:42 GMT 1
Conversions are short on sound deadening unless yours is a custom. Have you tried adding any more sound insulation? I would be curious to see if the running costs of a V6 would be more, given diesel costs more in the first place.
Deleted
Deleted Member
Post by Deleted on May 22, 2014 22:25:45 GMT 1
Conversions are short on sound deadening unless yours is a custom. Have you tried adding any more sound insulation? I would be curious to see if the running costs of a V6 would be more, given diesel costs more in the first place. Sound deadening is next on my list once I finally get round to stopping my windscreen rubber letting in more rain than is actually falling haha. My decibel Meter is currently recording an average of 95db inside the cab at about. 40-50 mph!!!! It's not just cab noise, the di is a redicicously loud engine. Having driven the last two weeks with the aircon on full/aka window down all the way it's clear that no amount of sound deadening will help in the summer! I actually drive with earplugs which are rated at -38 db reduction it's the only way my hour long journey each day is possible. I'm very Intrested to see if anyone actually can give me some v6 mpg experience to work with.
Deleted
Deleted Member
Post by Deleted on May 28, 2014 6:26:37 GMT 1
Any V6 people out there :/
Post by muttleymk2 on May 28, 2014 20:39:07 GMT 1
Don't even go there, if its a working truck you will be paying a fortune to run it. Budget for a maximum of 19-20 mpg and if you carry weight then you will be down at 14-15mpg. Essex is not the most reliable of lumps and is also hard to find in good condition and low compression transit form
Post by dodgerover on May 29, 2014 0:34:44 GMT 1
That's about the same as my pinto then mpg wise!
Post by muttleymk2 on May 29, 2014 20:06:10 GMT 1
Yeah, proper Transit V6 with single choke carb is less stressed than the Pinto
Post by bobdragon12 on May 29, 2014 21:04:00 GMT 1
I'm getting about 32mpg from my NA -DI with Turbo conversion . And that's dragging 2.8 tons around on its back
Post by stoney on May 30, 2014 20:39:40 GMT 1
my camper is essex v6 weighs 2.3ton and does 10-15mpg
my tipper is turbo di weighs 2.6ton and does 30mpg
my recovery is na di weighs 1.9ton and does 35mpg
Post by sidewaysjas on May 30, 2014 22:03:49 GMT 1
Thanks Stoney thats really useful info'
Jas
Deleted
Deleted Member
Post by Deleted on May 31, 2014 7:43:51 GMT 1
my camper is essex v6 weighs 2.3ton and does 10-15mpg my tipper is turbo di weighs 2.6ton and does 30mpg my recovery is na di weighs 1.9ton and does 35mpg Mines a tipper, in 1.7ton unladen. Nearly have some realistic mileage figures to put on. Is yours a twin wheel? I'm sure half the battle is my 5.13 diff. Thanks everyone for the figures I'll post ASAP as I have some figures, something tells me I won't be 35 though :/
Deleted
Deleted Member
Post by Deleted on May 31, 2014 8:32:20 GMT 1
Here's the old girl in question, everyone loves a picture Got to tow my escort 15 miles also so this will be included in the mpg test too....pics to follow
Post by bobdragon12 on May 31, 2014 9:28:01 GMT 1
I have the same issue with my diff but we only have one scrapyard on the Isle of Wight so it's a bit difficult to get hold of one
Post by stoney on May 31, 2014 9:55:34 GMT 1
Mines a twin wheel tipper extended chassis and bed with a HIAB crane, winch, ramps, dropsides and scaffold frame. Hence why it weighs so much! I'm not sure what the diff is but it cruises at 80 no problem.
Its currently undergoing some major surgery weight loss and a facelift!
Post by bobdragon12 on May 31, 2014 11:56:07 GMT 1
Mines a twin wheel tipper extended chassis and bed with a HIAB crane, winch, ramps, dropsides and scaffold frame. Hence why it weighs so much! I'm not sure what the diff is but it cruises at 80 no problem. Its currently undergoing some major surgery weight loss and a facelift! You must have a good ratio diff as I can't get mine above 50 with out the need for ear defenders , shame the 6 speed box won't fit
