Post by minitrans on Oct 2, 2015 12:17:30 GMT 1
I had problems with the later gearbox crossmember so I adapted the mk2 one. And also the later prop did not fit so I had one made up. you need the adapter plate for the gearbox to engine and a prop bearing/holder as the prop needs to slide in the middle best to ask mutley on here as he's done it aswell and remembers things better than me :-) how late is later ? #newbie I will do some research and get some info from mutley
Post by sleepy on Oct 2, 2015 12:47:14 GMT 1
Mine was from a pinto transit so probably a mk3/4
Post by FredTransit on Oct 2, 2015 13:22:33 GMT 1
Mk3 had the type9 (boo) Mk4/5 (92-2001) had the MT. If you go to this, wanna swap mats? I got a donor with OD and as Alex's MT is stuffed (fitted a decade ago!!) we are going with the OD. Going for originality
Post by minitrans on Oct 2, 2015 13:57:11 GMT 1
Mk3 had the type9 (boo) Mk4/5 (92-2001) had the MT. If you go to this, wanna swap mats? I got a donor with OD and as Alex's MT is stuffed (fitted a decade ago!!) we are going with the OD. Going for originality I will keep you in mind Anyway, I'm probably getting ahead of myself, the Transit works and sits on the motorway happily at 65, so I will concentrate on fixing up the inside first so we can go away and have some fun
Post by sleepy on Oct 2, 2015 14:37:46 GMT 1
If it sits fine at 65 then that's fine. A 5 speed will save a bit of fuel on the long runs. But make it homely first you will be living in it longer than driving it.
Post by FredTransit on Oct 2, 2015 14:49:41 GMT 1
Got to agree with sleepy. We did our MT conversions for long distance work. Now I want originality.
Post by muttleymk2 on Oct 2, 2015 21:20:47 GMT 1
How do to you, stick with the 4 speed and go retro with your driving style
Post by minitrans on Oct 5, 2015 8:58:27 GMT 1
Thanks for the advice guy's
