Post by minitrans on Oct 2, 2015 8:02:44 GMT 1
I best say hello to everyone , well I put a cheeky bid on ebay at the last second and wow it was mine . This is the only photo I have personally taken , I have a few plans to update it with a split charging system, 240v Hook-up and a heating system for now, long term we will have to see...... This is our first Transit and our first Camper, but I have been into the classic car scene for a very long time
Post by corktina on Oct 2, 2015 8:20:46 GMT 1
she looks to be in good shape.enjoy.
Post by sleepy on Oct 2, 2015 9:04:13 GMT 1
Welcome she looks nice
I want that bullbar :-)
Post by minitrans on Oct 2, 2015 9:11:26 GMT 1
Welcome she looks nice I want that bullbar :-) I am 50-50 if I should keep it on, probably costing me some mpg!!
Post by minitrans on Oct 2, 2015 9:14:03 GMT 1
I was wondering about a 5 speed conversion, doing a search I come up with so much info the mind boggles!!
Post by FredTransit on Oct 2, 2015 9:21:57 GMT 1
Welcome mate! The five speed isn't too hard. I am not a fan of the type9 as fitted in Mk3s. The MT75 is far better, but needs to have a new hole cut in the floor as the gearlever comes up from the box to the right of the 4 speed. Another option for you would be the overdive.
Post by minitrans on Oct 2, 2015 9:28:54 GMT 1
Welcome mate! The five speed isn't too hard. I am not a fan of the type9 as fitted in Mk3s. The MT75 is far better, but needs to have a new hole cut in the floor as the gearlever comes up from the box to the right of the 4 speed. Another option for you would be the overdive. I was looking at an MT75 conversion, I don't mind cutting a hole, as I can soon weld up the old one Are the o/d easy to get hold of, I bet they're not
Post by sleepy on Oct 2, 2015 9:46:19 GMT 1
Welcome she looks nice I want that bullbar :-) I am 50-50 if I should keep it on, probably costing me some mpg!! if you ever think about selling it let me know :-)
Post by sleepy on Oct 2, 2015 9:48:21 GMT 1
I am using the MT75 gearbox and it runs great. Much better than the type 9
Post by minitrans on Oct 2, 2015 10:35:26 GMT 1
I am using the MT75 gearbox and it runs great. Much better than the type 9 Might be a winter project for me , what's the best MT75 to go for?
Post by minitrans on Oct 2, 2015 10:56:02 GMT 1
So would it be a good option be to buy a rusty late 90's 2.5 td 5 speed swb transit and swap all the bits into mine?
Post by sleepy on Oct 2, 2015 11:28:52 GMT 1
I had problems with the later gearbox crossmember so I adapted the mk2 one. And also the later prop did not fit so I had one made up. you need the adapter plate for the gearbox to engine and a prop bearing/holder as the prop needs to slide in the middle best to ask mutley on here as he's done it aswell and remembers things better than me :-)
Post by corktina on Oct 2, 2015 11:39:32 GMT 1
Welcome she looks nice I want that bullbar :-) I am 50-50 if I should keep it on, probably costing me some mpg!! well can I join the q to buy it if you take it off?
Post by corktina on Oct 2, 2015 11:40:24 GMT 1
does it have overdrive?
Post by minitrans on Oct 2, 2015 12:15:34 GMT 1
no overdrive, but it sits at 65 okay so I guess it has a decent ratio final drive (something to check)
