Post by irishtransit on Dec 16, 2012 16:21:43 GMT 1
what would be a good price for a set of brand new unused leaf springs be?
Post by m201 on Dec 16, 2012 18:09:07 GMT 1
what would be a good price for a set of brand new unused leaf springs be? You buying or selling Irish?
Post by muttleymk2 on Dec 16, 2012 19:11:26 GMT 1
£10 each ;D
Post by m201 on Dec 16, 2012 19:47:26 GMT 1
I'll take all you've got at that price Muttley. When will you be dropping 'em off please?
Post by irishtransit on Dec 16, 2012 19:51:13 GMT 1
someone over 'ere has 'em for €100=£78?
Post by m201 on Dec 16, 2012 20:00:08 GMT 1
someone over 'ere has 'em for €100=£78? I prefer Muttley's they're cheaper Irish. ;D
Post by RDTranny on Dec 16, 2012 23:09:24 GMT 1
I think I if i remember correctly the fella in Portlaoise Springs did them for about €75 each. So if €100 for a set is not bad! Just make sure they are MK2 and not MK3 as the pin that places the axle is slightly further forward by about 1 1/2 inches on the mk3 ones. I've got a set of mk3s on mine and it does make the front wheels look a little strange but they work none the less if you adjust the steering.
Edit: I'm talking about front springs Btw. Haven't a clue about the rears!
Post by m201 on Dec 17, 2012 9:56:08 GMT 1
I think I if i remember correctly the fella in Portlaoise Springs did them for about €75 each. So if €100 for a set is not bad! Just make sure they are MK2 and not MK3 as the pin that places the axle is slightly further forward by about 1 1/2 inches on the mk3 ones. I've got a set of mk3s on mine and it does make the front wheels look a little strange but they work none the less if you adjust the steering. Edit: I'm talking about front springs Btw. Haven't a clue about the rears! Did you eva think aboit moving that pin RD?
Post by RDTranny on Dec 17, 2012 16:42:59 GMT 1
I have but I haven't a clue how I'd go about it!
Post by muttleymk2 on Dec 17, 2012 17:32:48 GMT 1
Mk3 fits MK2
Post by m201 on Dec 17, 2012 19:14:10 GMT 1
I have but I haven't a clue how I'd go about it! ;D I'd drive the old pin out, drill a hole in the right place, and knock the pin back in. The pin won't go anywhere one it's in.
If the pin wouldn't come out, I'd grind it off, and bodge a new pin.
If the pin's a bit loose, drivel a centre punch into it's sides a few times.
Except that I'd have a blacksmith hammer a curve into the old springs.
Muttley's probably got a better way if you ask him,
