Post by m201 on Dec 24, 2012 11:07:29 GMT 1
Post by fortyeight on Dec 24, 2012 14:08:54 GMT 1
not a bit like my mk2
Post by m201 on Dec 24, 2012 14:44:30 GMT 1
That's not surprising really 48, there were at least 12 different master cylinders for the 1.6 & 2 litre Mk2 Transits alone.
Post by fortyeight on Dec 24, 2012 14:48:46 GMT 1
if you want a straight changeover youll have check the part no/on alliuminium tag theres also 2 differant makes just forgot what they are now
Post by m201 on Dec 24, 2012 15:13:00 GMT 1
if you want a straight changeover youll have check the part no/on alliuminium tag theres also 2 differant makes just forgot what they are now The aluminium tag should be a good identifier 48. Actual piston sizes and strokes are better, since tags can get accidentally swapped.
Fords used at least ATE, Lockheed, and Bendix 48.
Post by FredTransit on Dec 24, 2012 15:24:49 GMT 1
thats a mk1 master but without comparison I dunno which model
Post by m201 on Dec 24, 2012 15:35:26 GMT 1
thats a mk1 master but without comparison I dunno which model You any idea what the hole with the blue plug is for please Fred?
Post by FredTransit on Dec 24, 2012 16:12:58 GMT 1
I am thinking a brake pipe outlet but not sure why its blue
Post by m201 on Dec 24, 2012 17:16:13 GMT 1
I am thinking a brake pipe outlet but not sure why its blue I think the blue shows a different size hole Fred. In the pic the blue plug looks smaller than the reds to me. Some had a control switch, but control switches have big fat threaded section. ;D
Post by muttleymk2 on Dec 24, 2012 20:51:27 GMT 1
Its a MK1 facelift cyl, blue hole is for a small threaded peg that stops the front piston coming too far back.
Post by m201 on Dec 24, 2012 21:09:05 GMT 1
Its a MK1 facelift cyl, blue hole is for a small threaded peg that stops the front piston coming too far back. Oh, ah, yes, thanks Gaffer. ;D
Post by FredTransit on Dec 26, 2012 16:52:18 GMT 1
Well that's cleared that one up, cheers Muttley. Knew it was a Mk1.
Post by m201 on Dec 26, 2012 18:10:13 GMT 1
Well that's cleared that one up, cheers Muttley. Knew it was a Mk1. Do you know if it's NOS or not though Fred?
Around the ports looks clean enough. Apart from that, it looks pretty dirty to me. Whilst, as far as I can recall, boxed master cylinders come without reservoirs. My sixpenn'orth says it's been used. And used with a dirty reservoir..
Do you know which model Mk1 it fits please Muttley?
Post by muttleymk2 on Dec 26, 2012 18:47:19 GMT 1
Dual circuit so post 72, impossible to say more without seeing the tag.
Post by m201 on Dec 26, 2012 19:04:33 GMT 1
Dual circuit so post 72, impossible to say more without seeing the tag. Thanks Muttley.
