Post by danclift on Nov 18, 2016 12:35:55 GMT 1
anyone know how fast my van goes ? its a mk2 swb panel van with a 2 liter pinto 205 block and twin choke weber and a 4 speed gear box. not sure how accurate the speedo is as it goes up to 90 mph and ive had that showing so pretty much went off the clock just wondering how fast these go then ? i did notice i was overtaking everyone lol
Post by FredTransit on Nov 18, 2016 15:04:50 GMT 1
Yes I have seen 'more than' that's more than the speedo will show. Your best bet is to use a SatNav that shows your actual speed.
Post by dodgerover on Nov 18, 2016 19:35:16 GMT 1
I think if I was sufficiently mechanically unsympathetic then I could probably wind mine up enough to top 90, don't think the old pinto would last pulling those rpms for long though
Post by danclift on Nov 18, 2016 20:03:27 GMT 1
well mine was not quite flat out it could have gone a tiny bit more but my speedo said 90 was wonering how much more tho
Post by sleepy on Nov 18, 2016 20:35:20 GMT 1
Like fred said use a sat nav for an accurate speed down hill on a motorway you should hit around 90-100 after a distance. uphill it's a another story :-) It all depends on your diff ratio as well my 1.6 pinto can hit 80 quite easily on the flat or downhill
Post by FredTransit on Nov 18, 2016 21:40:12 GMT 1
I used to kill a pinto a year doing motorway work with a four speed. Then we got MT75s!
Post by muttleymk2 on Nov 18, 2016 22:19:54 GMT 1
Have I missed summat or is this OSF
Post by bullsintransit on Nov 18, 2016 23:16:12 GMT 1
Think a LHD speedo cluster will make it go a lot faster if you believe all you read.
Post by FredTransit on Nov 18, 2016 23:26:10 GMT 1
Have I missed summat or is this OSF LMAO
Post by danclift on Nov 19, 2016 16:54:44 GMT 1
i normally do 60 on bog roads like motorway
