Post by dodgerover on Dec 3, 2016 22:24:31 GMT 1
That's cheating! It's is however what I would have done as a quick fix if mine was loosing water. Big chunk of gasket was missing between cylinder 3&4 I'm hoping it was just bad luck and not a sign the block needs a skim....head should be perfect it was skimmed last year. Any thoughts on retorqueing the torx type head bolts after a few heat cycles? Went with a Payen gasket as that's what I could get.
Post by bambimk1 on Dec 3, 2016 23:18:30 GMT 1
If your not sure where tdc is on the crank pulley set it near enough as you think tdc is and get some washing up liquid and make a bubble over the plug hole on no one .Rock the crank till the bubble is at its highest point
Post by dodgerover on Dec 4, 2016 1:00:12 GMT 1
If your not sure where tdc is on the crank pulley set it near enough as you think tdc is and get some washing up liquid and make a bubble over the plug hole on no one .Rock the crank till the bubble is at its highest point Bugger me thats clever! Need to remember that for future reference
Post by jonochap on Dec 4, 2016 20:43:06 GMT 1
Great work Dodge, how did you get on with tdc?
