Post by sleepy on Aug 12, 2017 15:49:09 GMT 1
Does this just happen to me or do any of you guys have this problem? Every time I check my spark plugs on my pinto the leads break off at the plug connectors when I pull them off. I even have to use pliers to pull the terminal off the plug when it's left behind. is there a certain way of pulling off the leads?
Post by dodgerover on Aug 12, 2017 18:22:54 GMT 1
No it's not just you. The magnecore ones are supposed to be better but I'm not paying that much for plug leads..
Post by muttleymk2 on Aug 12, 2017 21:41:35 GMT 1
Twist and pull only on the thick bit and a small dab of copper grease inside when you fit them helps
Post by sleepy on Aug 13, 2017 18:53:12 GMT 1
No i don't pull it by the lead :-) I always twist and pull the boot but so far every time I do it on the transit I'm left with a terminal on the plug. I'll try the copper grease and see how I get on
Post by muttleymk2 on Aug 13, 2017 21:20:40 GMT 1
You know it makes sense
