Post by irishtransit on Aug 21, 2017 17:39:31 GMT 1
how many bolts are there that hold on the manifold.i can see 4 on the top please tell me there are no hidden ones please please please. a pic would be handy.
Post by conrod on Aug 21, 2017 20:29:47 GMT 1
2 on each cylinder from memory, so 6 per side!
Post by muttleymk2 on Aug 21, 2017 21:18:34 GMT 1
Yeah, 2 on each outlet one top and one bottom.
Post by irishtransit on Aug 21, 2017 21:56:36 GMT 1
would anyone be able to show us a pic or something as i might be looking at the wrong ones. on the pic the ones i'm looking at you can just see to the left of the left hand spark plug. how hard is it to get to the lower ones?
Post by muttleymk2 on Aug 22, 2017 21:33:01 GMT 1
Effing hard, especially if you cant get underneath
Post by irishtransit on Aug 23, 2017 0:42:47 GMT 1
Effing hard, especially if you cant get underneath well that makes it awkward then because the front is so rotten i don't know if i want to get under there
Post by muttleymk2 on Aug 23, 2017 21:48:21 GMT 1
Can you pull the lump out?
Post by irishtransit on Aug 24, 2017 0:33:10 GMT 1
Can you pull the lump out? not really mutts. i've sent the guy a couple of links off ebay 1 for an o/s manifold and the other for a complete engine so that would make life easier n
Post by oldskooler on Aug 25, 2017 1:36:45 GMT 1
i dont fancy the look of those nuts that can be seen either,...i suggest a daily dose of wd 40 on em all for a few days and a hex socket when you do attempt removal.
you ill only get one chance!!
Post by corktina on Aug 27, 2017 12:24:32 GMT 1
and wire brush as much off the threads as you can before you start....bit of heat a good idea?
Post by irishtransit on Aug 27, 2017 17:25:23 GMT 1
i've decided not to go ahead for the time being much to sean's dissapointment.sorry again sean.
