Post by danclift on Sept 7, 2017 23:43:37 GMT 1
So Ralph tells me there are 2 different clutches and gearboxs mine is the 4 speed withbthe alloy rear section does anyone know if clutches can be swapped between them he sent me the bigger clutch as I thought my box was iron but it's not can I still use this clutch ? I have a 205 block pinto just wondering if anyone has changed parts between the 2
Post by muttleymk2 on Sept 8, 2017 22:33:55 GMT 1
Both type of clutch will fit your flywheel.
Post by danclift on Sept 8, 2017 22:55:27 GMT 1
Yea he said there is a 8.5" and 9.5" but I assume the holes for either would be in different places ? But if you say it fits it fits so what about the gearbox ? Would it fit that fine ? As I said mines a 4 speed with alloy tail
Post by muttleymk2 on Sept 9, 2017 21:25:25 GMT 1
The centre plate is the sizes he is talking about, the cover plate will fit your flywheel.
