Post by danclift on Sept 11, 2017 21:50:10 GMT 1
Valve clearance is definitely ok now cam bearings seem fine cam is good so the head is all ok I've taken dizzy out checked for play seems fine refitted and played with timing checked exhaust manifold is not blowing had inlet manifold off to make sure nothing loose had fallen down in there spark plugs are all tight have removed fan belt and ran engine so it's not the alternator or water pump flywheel seems tight not coming loose or anything it's pretty quite on start up but as it warms up it gets worse and worse on idle is tapping when revved it turns into a knock its got oil pressure and oil light goes out when started and has not come on wile running cam spray bar is ok and oil sprays as it should from all the little holes coolant is clean and so is oil it was running fine when left Brighton but when I got home I noticed the noise spent last 3 days on it with no luck
Post by muttleymk2 on Sept 11, 2017 22:05:07 GMT 1
Sounds like bottom end to me.
Post by danclift on Sept 12, 2017 10:44:52 GMT 1
I did take sump off and push the rods with hands didn't feel any play but how much play do you need to be abale to hear a knock ? Also what's in the small ends ? I can't find any bushes on eBay
Post by FredTransit on Sept 12, 2017 11:36:24 GMT 1
Any smoke? Could it be the rings?
Post by dodgerover on Sept 12, 2017 17:42:33 GMT 1
You don't need much play, a big end is usually a pretty unmistakable deep knock though. The video sounded like top end, but the quiet when cold and worse when hot sounds like a bearing.
Post by danclift on Sept 12, 2017 18:20:49 GMT 1
had the sump off again today had a good look and removed some caps the shells look as good as new and the crank is mint to cant feel any play anywhere down there i did undo the clutch cable and check the trust bearing its deffo gone and needs changing the noise seems a little quieter with the clutch cable taken off but i cant think what in the bell housing clutch wise would make a rattle sound ? it was the same when pedal was up or down till cable was taken off
Post by danclift on Sept 12, 2017 18:21:13 GMT 1
Any smoke? Could it be the rings? forgot to mention no smoke
Post by harry2012 on Sept 13, 2017 14:59:30 GMT 1
Sounds like pinking to me. Have tried altering the timing see if it goes away?
Post by bullsintransit on Sept 13, 2017 17:17:20 GMT 1
You seem to of checked everything engine wise( which most of it you've rebuilt) but not had the gearbox out to look at the clutch,which sounds as if it's slowly disintegrating from your posts. I'd look there if you can't see/find anything with engine but know clutch is shot,until that's sorted your throwing potential noise from dodgy clutch into the picture,but trying to find fault elsewhere.
Post by danclift on Sept 13, 2017 22:54:28 GMT 1
Took gearbox out today took clutch off duties engine back up still making noise someone came and looked at the cam and it feels rough when run my finger nail over the load seems the new cam kit is shagged after 10k miles with oil and filter changes every 2k miles
Post by bullsintransit on Sept 14, 2017 11:02:11 GMT 1
