Post by danclift on Oct 17, 2017 18:14:32 GMT 1
need help / advice. since ive owned the van its always had a problem with the hand brake i have replaced the rear wheel cylinders shoes and the hand brake cable. the problem is 50% of the times i pull the hand brake up it feels just fine but as it gets tight / to the top it suddenly makes a loud click / bang and the lever jumps up a few more inches.
Post by sleepy on Oct 17, 2017 19:44:48 GMT 1
Have you checked the handbrake lever itself it could be the spring or worn ratchet teeth
Post by danclift on Oct 18, 2017 8:39:37 GMT 1
No it's fine even if I push button it it does the same sounds like it's coming from the back like something clicks and suddenly I have more slack in the cable to take up
Post by muttleymk2 on Oct 18, 2017 20:56:17 GMT 1
Sounds like the self adjusters on the shoes slipping.
Post by danclift on Oct 18, 2017 22:04:05 GMT 1
Teeth on the adjusters didn't look bad tho sounds like it's coming from the rear driver side wheel are new adjusters all that expensive ?
Post by Ralph on Oct 19, 2017 6:45:52 GMT 1
I think I have them, I will check that I have some left. £40 inc P&P.
Post by danclift on Oct 19, 2017 12:47:03 GMT 1
Could it be the actual hand brake lever ? Can't see anything wrong under there tho and don't get how it suddenly has more slack in the cable to take up is this a common problem? Has it happened to anyone else ?
Post by muttleymk2 on Oct 19, 2017 21:24:48 GMT 1
Does the lever operate both sets of shoes, it may be the rear cable has broken.
Post by danclift on Oct 19, 2017 21:46:40 GMT 1
Yes as said I fitted new shoes and new cable that was about 3k miles ago but the van has always done this tho since I've owned it
