Post by chrisb23 on Nov 6, 2017 15:39:04 GMT 1
if any help it has the marks on the halfshafts from brake drums with this shape drum imgur.com/RviI5Nu
Post by chrisb23 on Nov 6, 2017 16:32:06 GMT 1
Post by chrisb23 on Nov 6, 2017 16:35:35 GMT 1
also has the rust mark on the half shafts from a brake drum like this imgur.com/1lJ1pKB
Post by FredTransit on Nov 6, 2017 19:06:02 GMT 1
Do imgur not offer the actual picture links? I added the tags as I can't find them. I find postimg easy to use postimages.org/They give you the codes after uploading.
Post by chrisb23 on Nov 7, 2017 8:35:20 GMT 1
Post by FredTransit on Nov 7, 2017 11:57:25 GMT 1
Post by chrisb23 on Nov 10, 2017 11:56:24 GMT 1
Post by FredTransit on Nov 10, 2017 19:18:53 GMT 1
You got it! So much better when you don't need to follow a link.
Post by chrisb23 on Nov 12, 2017 11:18:21 GMT 1
not done much to identify axle though
Post by muttleymk2 on Nov 12, 2017 22:03:21 GMT 1
Its definitely a Transit axle, without a tag number or casting number its hard ro narrow down.
Post by chrisb23 on Nov 12, 2017 22:28:35 GMT 1
unfortunately the tag is so badly rusted i cant make out all the numbers
Post by FredTransit on Nov 13, 2017 13:25:00 GMT 1
The tag's usually ally mate. Maybe it's got rust deposits off the axle? It could also be a bit squashed.
Post by chrisb23 on Nov 13, 2017 22:34:53 GMT 1
its defiantly steel unless iv got a alloy magnet, got it soaking in vinegar to see if it helps with rust removal
Post by muttleymk2 on Nov 13, 2017 22:53:42 GMT 1
Is there a cast number on the diff or axle casing?
Post by chrisb23 on Nov 16, 2017 13:46:59 GMT 1
the only bit i can make out on the tag top line looks like ok4500t34 bottom line 6v16001jo if any good
