jmh
New Star
Post by jmh on Nov 27, 2017 21:34:23 GMT 1
Hi all
Can anyone help me as i am looking to convert my left hand drive transit to right hand drive, Does anyonre know if anyone is selling a RHD steering box and associated parts ? or can i change the whole front end to suit a mk3 with coil springs ?
thanks for your help in advance
JMH
Post by FredTransit on Nov 27, 2017 21:39:48 GMT 1
Is this a Mk1? Try Ralph. You will need a steering box (with mounting panel) a pedal box, front axle (track rod) not sure if you can re use the servo/brake master. It's not too big a job if you have the parts, better yet a donor. IFS is a big job. Personally I would go for the beam axle, but that's just me!!
Post by muttleymk2 on Nov 27, 2017 22:29:33 GMT 1
What year is this van, if it is pedals thru the floor then its a lot of work to convert ro rhd. The Mk1 has a shorter chassis and the mk 3 front end wont fit without a ton of fabrication.
Post by Ralph on Nov 27, 2017 23:49:12 GMT 1
I have rhd steering boxes & mountings. You only need the ends, theres no need to change the whole axle. I can probably sort you with everything you need.
jmh
New Star
Post by jmh on Nov 28, 2017 10:16:12 GMT 1
I have rhd steering boxes & mountings. You only need the ends, theres no need to change the whole axle. I can probably sort you with everything you need. Ok. Can you have a look when you have a look for the manifold please. Also a price for everything needed. Much appreciated. Jmh
Post by Ralph on Nov 29, 2017 9:03:31 GMT 1
Ok, I can't find the inlet manifold but I will keep on looking.
jmh
New Star
Post by jmh on Dec 4, 2017 14:39:09 GMT 1
Ok, I can't find the inlet manifold but I will keep on looking. Hi Ralph I was wondering if you have had any luck on finding the steering parts and air intake ? Regards Jmh
Post by Ralph on Dec 5, 2017 7:21:15 GMT 1
I have steering boxes & axle ends but I cannot find the manifold.
jmh
New Star
Post by jmh on Dec 7, 2017 6:32:59 GMT 1
I have steering boxes & axle ends but I cannot find the manifold. ok. Ok What price are they ? Also do you have the steering column ? Brake servo ? Thanks.
