Post by danclift on Nov 28, 2017 21:45:47 GMT 1
cant feel any side to side play but there is quite a bit of up and down. so whats the limit and how is it measured ? also anyone have some good tips or info on changing them ? i have a new set so plan to change both sides soo as i have the time and the weather on my side.
king pins
Nov 29, 2017 14:29:59 GMT 1
via mobile
Post by FredTransit on Nov 29, 2017 14:29:59 GMT 1
Lift can be taken out with shims. They would have to be very bad to fail the MOT
Post by danclift on Nov 29, 2017 17:08:27 GMT 1
they feel quite bad and the van does bang quite a bit on the front end when going over bumps whats the best way to remove them ? heat hammer drill ect ?
king pins
Nov 30, 2017 11:13:52 GMT 1
via mobile
Post by FredTransit on Nov 30, 2017 11:13:52 GMT 1
For the banging, check the shock absorber bushes and gearbox mounts. The best way to remove old kingpins is to take the axle to an engineering company that has a press.
king pins
Nov 30, 2017 19:09:33 GMT 1
via mobile
Post by danclift on Nov 30, 2017 19:09:33 GMT 1
Fitted new shocks gearbox mounts are ok
