Post by johnbillard on May 29, 2018 22:15:55 GMT 1
Can anyone suggest a source of correct rear wheel studs? - 12 mm x 1.5mm pitch x 55 mm. The nearest I can find is from Burton Power but these require shortening.
Is it possible to replace these without disturbing the half shaft? I had new tyres recently and I suspect that the tyre fitter used too much torque. Result is 5 loose studs, wrecked wheel nuts and a damaged wheel.
Best wishes
John B
Post by Ralph on May 30, 2018 7:01:27 GMT 1
I think I have new studs somewhere, I will have look later.
Post by johnbillard on May 30, 2018 8:46:50 GMT 1
Thanks Ralph.
Most grateful if you could let me know as van is off the road - all five are needed on the rear off side.
Kind regards
John
Post by muttleymk2 on May 30, 2018 22:00:14 GMT 1
If memory serves me right you can knock the studs out without taking the hub off, pull them back in with a wheel nut and a tube spacer. I would replace the nuts as well
Post by Ralph on May 30, 2018 22:37:24 GMT 1
Yes I have 5, I think they are new.
Post by johnbillard on May 31, 2018 19:43:11 GMT 1
Thanks Ralph
I have managed to locate an eBay source - they appear to have 47 sets of 5 in stock! However if this doesn't work I will come back to you.
With kind regards
John B
Post by johnbillard on May 31, 2018 19:48:10 GMT 1
Thanks Muttley
No need to knock out the studs as they are already very loose. However they won't come out unless the brake shoes are removed or the hub comes off.
I will report back. Hope to do the job next week
Kind regards
John B
Post by johnbillard on Jun 1, 2018 11:45:10 GMT 1
Dear Ralph
Following a call from the eBay seller this morning (explaining their computer glitch) could you supply the five studs after all?
Most appreciated
John B
Post by Ralph on Jun 2, 2018 8:17:23 GMT 1
Hi John, I have messaged you. Ralph
