Post by wobbers on Jun 18, 2018 9:57:43 GMT 1
So, it seems I can open all my doors with pretty much any key. Typical old Ford I know! Are there any modern locks with an original look I can use? (It's a mk1 campervan). I can always install a lock on the inside of the rear door, but the front doors I'm unsure about. What have others done?
Post by bullsintransit on Jun 18, 2018 10:48:34 GMT 1
Might sound arse about face but on german firevans only the drivers door has key, rest are only lockable from inside apart from rear door ( not lockable, fitted internal deadlocks), external handles have no key, (apart from drivers door), handles come up regular on german ebay, just if there’s only one door with an external key there’s only one lock to worry about (or only one door you need to fit an external key for deadlock to), if it a camper you should be able to lock rest internally no prob.
Post by sleepy on Jun 18, 2018 17:47:01 GMT 1
how about solenoid on a remote as an extra lock on the front doors
Post by dodgerover on Jun 18, 2018 20:44:13 GMT 1
An old fashioned disc lock - the type that covers the entire wheel, not the silly bar things that are just useful extra leverage to break the steering lock. You need the large size.
Post by muttleymk2 on Jun 18, 2018 21:40:47 GMT 1
I have fitted most of Freds vans with extra security locks low down on the doors, front and rear
Post by wobbers on Jun 19, 2018 9:31:52 GMT 1
Some good ideas there, thanks. Muttleymk2, have you got any pics of the locks? I think I may go down this route.
Post by muttleymk2 on Jun 19, 2018 21:30:15 GMT 1
I will ask Fred to take some
Post by phorbiuz on Jun 21, 2018 19:23:50 GMT 1
Although never the best security when working fully, sometimes it's a case of dried out grease on the barrel pins causing them to stick open. You can strip, clean, and re-grease them so it'd be better.
Post by wobbers on Jun 21, 2018 21:50:14 GMT 1
The locks all open and close as they should. It's just that any old key will do the job. I'm going to do as muttleymk2 suggested I think, buy I'm not having much luck in finding a suitable lock at the moment.
