Post by paddywagon on Jan 15, 2013 9:39:06 GMT 1
Hi All, Can anyone tell me the diff ration that can be got for the Transit MK2 (My one is the single axle)
Post by FredTransit on Jan 15, 2013 11:21:04 GMT 1
depends what engine you have and what you want to do. Have TBH ratios are a bit of a mystery to me, but I do know some ratios are best for towing and others for motorway speeds, and also it depends on the fuel type. That having said we have never changed an axle (easier than doing the diff) when converting from petrol to diesel. Why do you ask?
Post by mk1andy on Jan 15, 2013 15:09:08 GMT 1
depends what engine you have and what you want to do. Have TBH ratios are a bit of a mystery to me, but I do know some ratios are best for towing and others for motorway speeds, and also it depends on the fuel type. That having said we have never changed an axle (easier than doing the diff) when converting from petrol to diesel. Why do you ask? It's easier to do a diff than the whole axle on a single wheeler Fred. Muttley's the man to answer the ratio questions me thinks
Post by muttleymk2 on Jan 15, 2013 16:58:20 GMT 1
You can tell the ratio from the axle code on the vin plate, they vary from 5.11 (short/more revs) to 3.9 (tall/less revs) with the 4.63 in the middle (ideal)
Post by paddywagon on Jan 15, 2013 17:27:36 GMT 1
It was originally a petrol (2 litre pinto) now fitted turbo DI. My current ratio is 4.44 and was woundering was other options had I ! So with the above info 3.9 would be the tallest gearing I coud get ?
Post by RDTranny on Jan 15, 2013 17:38:50 GMT 1
Yeah 3.9 is the tallest alright. 4.11 is available too assuming its the square axle.
Post by FredTransit on Jan 15, 2013 17:41:15 GMT 1
depends what engine you have and what you want to do. Have TBH ratios are a bit of a mystery to me, but I do know some ratios are best for towing and others for motorway speeds, and also it depends on the fuel type. That having said we have never changed an axle (easier than doing the diff) when converting from petrol to diesel. Why do you ask? It's easier to do a diff than the whole axle on a single wheeler Fred. Muttley's the man to answer the ratio questions me thinks Ah good point, we have only needed to replace twin wheelers (so far)
Post by franc on Jan 16, 2013 10:11:55 GMT 1
I read on another forum that later transit diffs can be fitted to the mk1, and mk2 axles, is this true? What limitations would there be (axle types)? Can a later axle be fitted to an early van without modification?
Post by FredTransit on Jan 16, 2013 11:53:44 GMT 1
some diffs need a carrier to keep them together when removed from the axle which is why we have changed the full axle in the past. That too could also be a twin wheel thing......
Post by muttleymk2 on Jan 16, 2013 17:02:45 GMT 1
I read on another forum that later transit diffs can be fitted to the mk1, and mk2 axles, is this true? What limitations would there be (axle types)? Can a later axle be fitted to an early van without modification? Diffs can be interchanged between like axles, I:E square or round tube regardless of year.
Post by paddywagon on Jan 16, 2013 22:42:31 GMT 1
Ok thank you, mine a the square type, will start looking out for the 4.1 diff. I also need to tow a car and trailer so I need to be careful not to over gear it !!
Post by oldskooler on Jan 31, 2013 11:05:56 GMT 1
im told you can use the mk5 4.1 complete diff assembly (pigs head) in a square axle. but you will have to swap over the mk2 spool or side gears as the half shaft splines are different. i havent tried it yet myself.
Post by RDTranny on Jan 31, 2013 23:36:59 GMT 1
Thanks oldskooler you just reminded me. I have done that a couple of years ago when i laid my hands on a 94 axle. You do have to swap the side gears but thats handy enough as they stay in the carrier that bolts to the crown wheel assembly. Took a little while to realign the crown wheel when putting it back together. You're supposed to use dial gauges to set up preload and backlash. But i set it up so that i could feel a tiny bit of movement between the gears. Seemed to work out ok.
Post by FredTransit on Feb 2, 2013 13:33:45 GMT 1
personally I would just swap the whole axle........
Post by RDTranny on Feb 3, 2013 22:46:51 GMT 1
As would I, 8 bolts, a couple of brake cables and hoses, and a bit of brake bleeding is a lot easier than cracking open a diff, but when you haven't got an axle it's good to know what you can do.
