Post by shawn74 on Mar 8, 2021 15:41:32 GMT 1
Hi all,
Can someone recommend a electric fuel pump/ filter for my York 2.4 MK2, It still has the original glass bowl filter which probably hasn't been touched in yonks...
Thanks
Shawn
Post by muttleymk2 on Mar 8, 2021 22:35:28 GMT 1
Theres a variety of electric pumps available on Ebay, also maybe use a later Di filter and head assembly.
Post by shawn74 on Mar 8, 2021 23:16:53 GMT 1
Theres a variety of electric pumps available on Ebay, also maybe use a later Di filter and head assembly. Ah ok...so I can use a "normal "filter...does that screw on to the head assembly? Sorry for the silly question...
Post by shawn74 on Mar 8, 2021 23:35:54 GMT 1
Theres a variety of electric pumps available on Ebay, also maybe use a later Di filter and head assembly. Ah ok...so I can use a "normal "filter...does that screw on to the head assembly? Sorry for the silly question... Would this do the job? Thanks Shawn
Post by muttleymk2 on Mar 9, 2021 21:52:31 GMT 1
Yes, that will do with the correct head unit, some re-piping may be necessary. Keep in mind flow and return including injector leak off pipes.
