Post by rosco on Aug 25, 2022 19:48:05 GMT 1
Hi had to replace the front spring hangers but the chassis rail behind them is needing replaced. Just wondered if you can buy a piece of box section to the replace the bad or any other ideas what be much appreciated. Thanks
Post by conrod on Aug 25, 2022 20:14:28 GMT 1
Ralph may be able to sell you a piece. Otherwise, cut the damaged part out, and give to a sheetmetal fabrication dude and get him to fold you up a new piece to weld in. Here is the rear spring hanger mount which my sheetmetal dude recreated on my current resto project
Post by muttleymk2 on Aug 25, 2022 23:15:28 GMT 1
It should be simple to fabricate a section, use 1.3mm steel.
Post by Ralph on Aug 29, 2022 7:10:34 GMT 1
I have the remains of 2 MK1 chassis cabs coming in early September so I might be able to do some chassis cuts. Have you tried Dan Clift as he had some front chassis legs?
Post by rosco on Aug 29, 2022 21:48:55 GMT 1
OK thanks for the replies I will give Dan a try.
