Post by capriv4 on Apr 23, 2023 8:39:02 GMT 1
Has anyone put a Mk 1 cab on a later with no rust chassis, so you get the best look cab and a good no rust chassis?
Post by muttleymk2 on Apr 23, 2023 21:03:47 GMT 1
Anything is possible, there have been a few Mk6/7 vans reskinned with mk1 panels. The Mk1 truck doesnt have a seperate chassis ar the front so as such is not removeable. Probably easier to update the Mk1 with later engine and running gear.
Post by capriv4 on Apr 28, 2023 8:54:41 GMT 1
The cab and running gear 2000 V4 and diff with MK 3 crown wheel and pinion all good but chassis completely rust eaten still holding together is flat deck maybe the deck is helping.
Post by muttleymk2 on Apr 28, 2023 21:48:12 GMT 1
If it helps the chassis was the same right up to Mk3.
