Post by jnwferguson on Jan 24, 2013 22:03:53 GMT 1
Hi guys need wiper blades for my 1979 camper mk2.anyone know where I can get a set it is the type with the flat blade 8mm arm not the hook type as everyone seems to sell now or where can I get new arms. thanks in advance jim.
Post by FredTransit on Jan 24, 2013 23:01:23 GMT 1
Very important. Keep the plastic bit that attaches to the arm. You can then fit pound shop wipers!! ;D Which is what I do with the Mk1s. They have the same flat arms. It's the adapter thats the key. You don't get that one in the pack.
Post by jnwferguson on Jan 25, 2013 13:48:08 GMT 1
problem is these wipers have the adaptor riveted to the arm the only way I can see is to get those refill rubbers anyone have any other ideas. thanks jim
Post by FredTransit on Jan 25, 2013 20:22:24 GMT 1
unclip them from the arm and see if the plastic bit can be removed from the blade. Failing that maybe you can slide the rubber out of the cheapo ones and use em to refurbish the originala?
