Post by bobdragon12 on May 17, 2013 11:02:29 GMT 1
If I want a rev counter is there a transit binicle available or did FORD use the same Binicle on other vehicles that will fit . Cheers jon
Post by muttleymk2 on May 17, 2013 16:14:03 GMT 1
You can use the gauges from a MK4 or 5 Cortina, they have a rev counter
Post by transit9 on May 17, 2013 17:03:19 GMT 1
i got one off e-bay for £12, mounted it next to speedo,easy to wire just 12volt and coil feed.
Post by troppo on Jun 5, 2013 14:41:31 GMT 1
MKII escorts had a tacho on the RS models
Post by bobdragon12 on Jun 11, 2013 12:03:13 GMT 1
You can use the gauges from a MK4 or 5 Cortina, they have a rev counter Will mk2 granada clocks fit ?
Post by muttleymk2 on Jun 11, 2013 22:40:43 GMT 1
Nope.
Post by bobdragon12 on Jun 25, 2013 20:38:20 GMT 1
Right here goes , have got a late mk3 /early mk4 dash pod . Thought in fords wisdom it would be plug and play , silly of me really , after looking at both pods and moving all the pins about I have everything working except the high beam light which I think is a bulb issue and the rev counter its self . The rev counter obviously has a 5 pin(only 4 in use ) 2 are used for the clock lights and the other 2 for the rev counter . The issue I have is I can't find my cortina haynes as its been 16 years since I last had a mk5 . Does any body have a manual that can check or does any body now which to wires to input is it just a ground and a positive from the coil . Cheers jon
