Post by lc762 on Jun 6, 2013 12:05:03 GMT 1
i have a mk2 transit camper the brake master cylinder appears to be leaking at the join with the the servo, its only a slight dribble which runs down to the bottem of the servo it starts just below the join with the master cylinder, is this a easy fix ? any answers would be gratefully received,thanks
Post by jonochap on Jun 10, 2013 7:51:40 GMT 1
I found finding a new master cylinder was the best route for me and was lucky that servo was good on its own. There were some who recommended fixing the master but the service kit alone is expensive and not easy to get right...apparently
Post by muttleymk2 on Jun 10, 2013 15:07:12 GMT 1
You have a leak from the rear seal on the master cylinder, as Jono says, you need a rebuild or a new master cyl
