Post by transitmanred on Jun 20, 2013 16:27:27 GMT 1
Hi, I have a 1979 Mk2 campervan, Its been stood outside, under a caravan cover for seven months. So pre MOT, i've done a few checks and there are no dash lights, fuel gauge, heater gauge, warning lights working. I have checked the nine fuses, right hand side of the dash , all working OK. What do I check for next, take the dash out? Also the wheel nuts are rusted on, I have no way of heating them, so WD40 them and use a big bar, may snap the studs off, are they easy to replace, if this happens? Hope you can help, many thanks Transitmanred.
Post by mk1andy on Jun 20, 2013 17:24:07 GMT 1
Is it a 6 stud twin rear wheel van? If so, the left hand wheelnuts will be left hand thread mate.
Post by muttleymk2 on Jun 20, 2013 19:31:39 GMT 1
Have you tried taking the fuses out and cleaning the ends and also the terminals in the fuse box. a quick way is to rotate the fuses in situ and see if the lights come on.
Post by FredTransit on Jun 21, 2013 21:04:38 GMT 1
the main fuse to check is the one with the little dial symble. Thats the one that controls the dash. Also have a look at the main wiring loom junction in the glove box.
Post by transitmanred on Jun 23, 2013 18:00:03 GMT 1
Have you tried taking the fuses out and cleaning the ends and also the terminals in the fuse box. a quick way is to rotate the fuses in situ and see if the lights come on. Thanks tried this and got the petrol and water gauge working, thanks.
Post by transitmanred on Jun 23, 2013 18:03:33 GMT 1
Is it a 6 stud twin rear wheel van? If so, the left hand wheelnuts will be left hand thread mate. The wheels are 5 stud, tried heating them up with a blow torch, and even bent the longer bar i was using for extra leverage. When she goes in for an MOT, i will get the garage to try and undo them.
Post by supersport on Jun 23, 2013 22:04:57 GMT 1
where abouts in hampshire are you? if you are not that far away i can pop up and give you a hand if you want.
Post by transitmanred on Jun 24, 2013 14:49:35 GMT 1
where abouts in hampshire are you? if you are not that far away i can pop up and give you a hand if you want. Thanks for the offer, I have booked it in for an MOT on Monday and the garage is going to have ago at shifting them. I live in Bishopstoke, near Eastleigh.
