Post by muttleymk2 on Jul 28, 2013 19:31:32 GMT 1
Regardless of country of reg the vin plate should have GVW top line, GTW second line and then the front and rear axle weights respectively
Post by bobdragon12 on Jul 28, 2013 20:31:57 GMT 1
Regardless of country of reg the vin plate should have GVW top line, GTW second line and then the front and rear axle weights respectively Woll chdck in the morning when the kids awake . Back to the wine
Post by dodgerover on Jul 28, 2013 21:18:45 GMT 1
Looking at the way the spelling has gone on this thread I don't think you're the only one with a bottle.....Have a good holiday
Post by FredTransit on Jul 28, 2013 21:22:59 GMT 1
are they asleep in the cab? the VIN plate should be on the passenger step. Mabe the drivers oj yours....
Post by bobdragon12 on Jul 29, 2013 8:04:37 GMT 1
Pictures of plate . Except VIN
Post by bobdragon12 on Jul 29, 2013 8:09:22 GMT 1
Second time lucky Attachments:
Post by FredTransit on Jul 29, 2013 9:32:59 GMT 1
your vans gross weight is 3100kg. The next number down is the gross train weight when towing. Anybody can drive the van as its under 3500kg.
Post by bobdragon12 on Jul 29, 2013 10:45:25 GMT 1
Excellent news . Thought it was a little odd
Post by bobdragon12 on Aug 3, 2013 14:03:55 GMT 1
Right , I think I'm going to change to the 2.5di as the I'm only getting about 18mpg on petrol or LPG and the LPG produces less power than the petrol and the LPG tank is currently in the van and the time and money spent re-sighting the tank under the van and replacing the 10 plus year old lpg tank .anyway I need to find a donor van what sort of things do I need to look for and how much work is really involved
Post by FredTransit on Aug 3, 2013 19:16:04 GMT 1
its not too bad. The donor van is the way to go. you need
engine rad mounts (may be able to use yours not sure)
think about going for an MT75 at the same time
MT75 gearbox propshaft
you need to cut a hole in the floor to the right of the original. If your pinto is OK can I have first dibs on it?
Post by bobdragon12 on Aug 3, 2013 19:42:41 GMT 1
I have the mt75 . Will go for a complete van , what's the wiring like does the engine have a seperate loom to the main loom and I assume the newer vans have imobelis
Post by bobdragon12 on Aug 3, 2013 19:43:20 GMT 1
Immobiliser
Post by dodgerover on Aug 3, 2013 21:15:52 GMT 1
Easily bypassed is the immoboliser, get a lump with a Bosch pump not the Lucas EPIC set up, i'll ask for Fred, who much for the Pinto and LPG kit?
Post by bobdragon12 on Aug 3, 2013 22:35:32 GMT 1
I just have to find a donor van with a Bosch pump. As for the engine not long bought it from Muttley so it can be had for what it cost me as for the lpg not really looked at the resell but I would of thought £250 would be a far price
Post by dodgerover on Aug 3, 2013 22:48:46 GMT 1
LWB 6 stud axle van had the most ponies as standard if you can find one but they are all pretty easy to mess with, its only the pump and injectors that are different...
